- 17 Aug 2003
- Woburn Sand Dunes
3minit does full transparent no problem
no, no problems here. did you download it via the foxhound OTA thing?
Easy way to root is to flash a pre-rooted rom from here - MEA is one of the latest, so you'll root and update your rom at the same time.
http://forum.xda-developers.com/showthread.php?t=2250824
Pick:
choose the below file
Use the Android host as its faster to download.
Once you have downloaded the ROM, put your phone in download mode and open Odin and flash the ROM as PDA.
Watch this video on how to use odin:
http://www.youtube.com/watch?v=vlsO5o_-CI8
Benefits of rooting:
- Proper adblocker
- Use extra settings in apps that need root access e.g. Nova launcher, hide time on desktop status bar
- Delete system apps (bloat)
- Make full app backups with games saves, app settings etc using Titanium Backup.
Next step is to install a custom recovery like CWM or TWRP. This enables you to install custom roms, tweaks, system wide themes etc.
You can also use it to make a backup image of your whole rom and settings.
Youtube is your friend - watch a load of videos.![]()
Ive ran into a problem...
Wanted a clean install so in Download mode installed I9505XXUBMEA-PRE-ROOTED-ODEX-FULL.tar.md5 in Odin
Then installed Recovery using Odin after system booted up.
Copied FoxHound Rom over to phone.
Rebooted into recovery.
Wipe Cache
Wipe Dalvik
Install FoxHound.
Installs fine and then i reboot.
Reboots...see GT9505 boot image......reboots again...goes into recovery...
Any ideas why its doing this?
There is only one version of FoxHound...right?
FoxHound_GearEngine_0.5_By_Snakes_GT-I9505.zip
only one version, yes. Start the process again. weird. Dont bother wiping the cache or dalvic before installing foxhound as it does that as part of the install anyway and the instructions dont tell you to wipe them, only data and that's optional.
For some reason when i us FH OTA to get 3minit framework. It downloads and then does nothing......doesn't appear in Xposed installer with other modules.....
have you flashed it?
Lol so reboot into recovery and then just install? or do i have to wipe cache and all that nonsense too?
