7970 Vs 770 - Stock & OC Gaming Benchmarks
This is why I never trust paid reviewers. That Hitman bench is a standardised in game bench result, so all those fluctuations are clearly wrong and the same goes for Tomb Raider.
A few brown envelopes fly about me thinks :D
The problem is that not every site uses the in game benchmark. If they did then our results would more often match up. I hate benching games without an in game benchmark, its not consistent enough. At least i know with Hitman, Tomb Raider, Sleeping Dogs, Bioshock etc you get the same results everytime.
ah yes i forgot i have a SC version for a moment :)
Jim see how you stack up to a clocked 7970 in Tomb Raider.
Copy these settings
1080p, Ultimate preset, FXAA only, and use TressFx. Overclock that 770 as far as it will go and post your benchmark score.
Agreed.
When we did the BF3 bench, if someone was pap at it and someone was awesomes, the results would not tally up even on the exact same systems.
I do wish more devs would implement a standardised bench like Tomb Raider/Bioshock/Metro LL etc.
Will do give me 10 mins :)
Atta boy. This is what Scotty managed with his 770.
2500k @ 5.0
770 Lightning 1385/8210
Uploaded with ImageShack.us
Agreed.
Yes will be delighted if they get a proper bench in bf4, really hope they do. Will settle some arguments for sure. :p
Definitely cpu bottlenecked at 1080p with x4 AA. Even with the cpu at 5ghz usage was still only 67-77%.
With x8 usage was a bit higher, 87-97%, though it only crept up to 97% at the end.
67.8fps avg
Not bad, you need to find a few more fps to tie with scotty and double that to catch the 7970 though.
With a little more tweaking
CPU @ 4.4ghz
GPU 1320mhz | Memory 1987mhz
Guys this could end up an expensive new habit for me chasing numbers lol.
Good fun innit. :D
Here's a cheeky little 7950 entry at 1225/1750 to beat Jim's 770. Might be able to squeeze a bit more out of it yet, so scotty should prepare an orifice in case this £200 gpu takes the lead. :D
Thats an impressive score for a 7950 but isnt TressFX like running PHYSx on an AMD card?
No as TressFX and Direct Compute are open to everyone. Its basically just part of Directx 11.
Taken from Toms
"TressFX will provide realism to hair rendering in ways that otherwise can only be done with CGI or pre-rendered scenes. The trick to this is DirectCompute, allowing much better visuals with a minimal impact on CPU performance. The technology is similar to Nvidia's PhysX, making the GPU do the computations rather than the CPU."
Taken from Wiki
"Microsoft DirectCompute is an application programming interface (API) that supports general-purpose computing on graphics processing units on Microsoft Windows Vista, Windows 7 and Windows 8. DirectCompute is part of the Microsoft DirectX collection of APIs and was initially released with the DirectX 11 API but runs on both DirectX 10 and DirectX 11 graphics processing units."
I need to try and beat Scottys score. :D
Sorry for the delay :o
1250/1900
1300/1800
Yay! An extra 2fps min and 1.4fps avg! So worth it.
Well done Petey. Now see if you can break my sleeping dogs records posted earlier. :D
Did you have to drop the memory down to get 1300 stable? I find 1823 is a good number but if you can go higher then that should help so long as error correction is not kicking in.
Nah, I used Trixx to get the core voltage over 1.3 but there's no memory voltage adjustment on there unless there's a modded/newer version about.
Can I get AB to run over 1.3v?
I haven't really been keeping up with stuff tbh :o
