Best motherboard for my build?
13 Jun 2013
Hi, I'm going to be purchasing these parts soon:
YOUR BASKET
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor & Corsair H100i CPU Cooler Bundle with FREE Grid 2 PC Game £364.99
2 x Gigabyte GeForce GTX 770 WindForce 3x OC 2048MB GDDR5 PCI-Express Graphics Card (GV-N770OC-2GD) £349.99 (£699.98)
1 x NZXT Phantom 820 Enthusiast Full Tower Case - Black £199.99
2 x Samsung 256GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD256BW) £187.99 (£375.98)
1 x Corsair Vengeance Pro Red 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (CMY16GX3M2A2400C10R) £179.99
1 x XFX Pro 1000W Black Edition '80+ Platinum' Certified Modular Power Supply £149.99
1 x Western Digital Caviar Black 2TB SATA 6Gb/s 64MB Cache - OEM (WD2002FAEX) HDD £119.99
1 x Corsair Fan, SP120 PWM High Pressure Fan 4 pin, Dual Pack (CO-9050014-WW) £25.99
1 x LG GH24NS95 24x DVD±RW SATA ReWriter (Black) - OEM £17.99
2 x BitFenix Spectre PRO 200mm Red LED - Black £14.99 (£29.98)
4 x BitFenix Spectre PRO 140mm Fan - All Black £12.98 (£51.92)
Total : £2,237.03 (includes shipping : £16.85).
I have all the parts listed ready to order exept for the motherboard, which board would be the best taking into account the parts I have chosen, and that I will be overclocking and may go 3 way SLI in the future?
Price range for the board is £150-250, and colour matching if possible. Though this is not essential.
Cheers
Alright, well I'll just go for a 2 way one for now and upgrade the motherboard if I decide to go 3 way SLI.
Is the UD4 the best board in this price range, taking into account everything?
Also would using 4 sticks rather than 2 make any differance at all?
The best board in that sort of price range is the Giga OC (currently on offer as well) I didn't mention it as it is black and orange.
2 sticks is usually better than 4 as its gentler on the memory controller, but this will be noticeable only if you are planning on going extreme cooling and overclocking.
Shame that board isn't red and black :/
What makes it better than the others btw? Is it just as it is more optimized for overclocking?
Think I'll stick with the 2 sticks for now, which will allow me to add another 2 if I ever need it.
It's one goal is overclocking, it has all the features you need to break CPU's at extreme frequencies and at extreme sub zero temps.
Apparently 8 Pack says the BIOS has been well designed to work with hardware (fine tuned for high end gear).
http://forums.overclockers.co.uk/showpost.php?p=24503952&postcount=24
http://forums.overclockers.co.uk/showpost.php?p=24511169&postcount=5
I do have one also, must admit, it's a monster board for the money, got my CPU superPI stable at 4.9Ghz on air, can get into windows at 5Ghz (all on air cooling), tunes RAM well..and I'm not even a pro overclocker.
Ah I see. Well I don't think I'm going to be extreme overclocking any time soon.
Which is better for mid range overclocking, say 4.5/6MHz. The Gigabyte UD4 or the Asus Hero board? Since both of these boards match my colour scheme and are pretty much similar prices
Alright, cheers! I'll get the UD4 then. I've seen reports of the 4770k getting upto 4.7GHz, so I'm assuming 4.5 will be achievable. If not anything over 4 will be good enough for me.
I'll also look into that cashback offer, cheers for the help :)
Good choice there, love the Gigabyte boards cause I've got one lol. Check out the Corsair Vengeance pro ram, it's great.
http://www.youtube.com/watch?v=jtJJTo7OM1k
You can get it here...
http://www.overclockers.co.uk/showproduct.php?prodid=MY-371-CS&groupid=701&catid=8&subcat=1387
Edit: Sorry just saw you have already chosen the Vengeance ram, excellent.
Edit 2: Sorry Stulid, just saw your link for ram, you beat me to the nerd pOrn lol.
I would havE Gone the OC on this one mate. The UD4 is a good board though.
The OC has some great tweaking options and the obvious stability even when not extreme overclocking. If with 1.8 Vcore amd nearly 3v VCCIN I cant break it, then no one can!!!
would have pushed it, but went for style over substance in this case.
Would have went with it if it wasn't orange :p
Can't have it clashing with my colour scheme!
Also I'll probly end up getting another 2 16GB sticks in the future, so I'll get the silver ones then, for that nerd p0rn!
