First.... I`m a tad concerned that my initial appraisal "acht it will be ok", might not be accurate lol, I intend (ed?) to tile a part of sloping ceiling in my bathroom, however as the actual deed looms I`m getting concerned incase its a bit mental, essentially the slope is as in the pic below, tile is porcelain and 600mm x 300mm x 8.5 mm............question is will they fall off?, I`ll be using decent cement based powdered adhesive (not the ready mixed stuff), also if we think it will be ok any novel methods of holding them in situ till adhesive sets?
An additional query is my planning.....I`ve tried a rough panorama shot on my phone to illustrate, The tile sitting on the batten is where I *think* my first tile should be, extreme left is door frame, extreme right is where bath will be, I intend starting on a full tile from extreme right so that both walls will meet in middle corner with decent sized cuts (and in the middle corner will be the least seen area as one side of three sided shower will obscure), from first tile to floor is exactly one tile leaving a cut for the top at the ceiling.
Essentially am I about to make any glaring errors?
, BUT it seems I have no alternative but to attempt it
