Do any of those actually work? I get such bad hayfever and when I tried some medication last timer for it it did nothing. I just sit it out now.![]()
Added the original soundtrack to Goldfinger on vinyl to my Bond collection (Thunderball soundtrack is still to come) along with Star Wars / A Stereo Space Odyssey although thats not the original soundtrack.
Thats my new one on the left:
Bit of an upgrade compared to the one on the right.
1200x900 bed, 80W lasercutter!
Oh very nice, have you got the black hole soundtrack, very good, had mine since 1979.
http://www.discogs.com/John-Barry-The-Black-Hole-Original-Motion-Picture-Soundtrack/release/1798970
There are like 5 variants of hay fever meds you can get, only 1 needs prescription for, although you can still get it if you have a chat with a pharmacist.
There are also nasal spray, which are anti inflammatory than antihistamine. These takes a constant use for a few days for the drug to build up in the system to help the sinuses.
I found cetinzine and Loratadine does nothing at all for me, I even took them both together, or double the dose, zilch, nothing.
Then I tried Acrivastine which is much much better, combine with beconase spray I have been "cured" since using his combo.
But everyone is different, I would suggest you speak to your GP if you are suffering badly from it.
Only trouble with the nasal sprays is that they can only be used continuously for like a month else it starts to thin the lining of the nose and you lose the sense of smell.
Not using it until I've replaced my motherboard and processor (upgrading to haswell).
Replace the fans with 4x SP PWM 120mm, Job done.
[/QUOTE]
Which model?
