- 20 Jul 2009
- The bleak North East arm pit of Britain
The most powerful AMD 990FX board on the market is back and OcUK have an UK Exclusive!
This is one of only 3 boards that are known to be able to take and overclock the new FX-9590 CPU from AMD and from testing internally is by far the fastest and most stable!
If your a massive AMD fan and you want the best then the UD7 is the ONLY board for you!
Gigabyte 990FXA-UD7 Rev 3.0 AMD 990FX (Socket AM3+) DDR3 Motherboard @ £199.99 inc VAT
The 990FXA-UD7 motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via the GIGABYTE 333 onboard acceleration technologies. Featuring the USB3.0 controller, AMD 900 series motherboards allow users to take advantage of super fast USB transfer rates of up to 5Gbps, delivering 10x faster data transfer compared to USB 2.0. Utilizing the industry's first Serial ATA Revision 3.0 solution via AMD SB950 chipset, GIGABYTE AMD 900 series motherboards offer native 6 ports of next generation high speed data storage devices support with data transfer speeds of up to 6 Gbps with RAID 0, 1, 5, 10. The AMD 900 series motherboards introduce a unique hardware design with lower resistance fuses for ensuring lower voltage drops and providing more stable and plentiful power delivery. All USB ports also benefit from a 3x power boost for better power delivery to power hungry USB devices.
Specification:-
CPU
- AM3+ Socket:
- Support for AMD AM3+ FX processors
- Support for AMD AM3 Phenom™ II processors / AMD Athlon™ II processors
- Hyper Transport Bus: 5200 MT/s
Chipset
- North Bridge: AMD 990FX
- South Bridge: AMD SB950
Memory
- 4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory (Note 1)
- Dual channel memory architecture
- Support for DDR3 2000(O.C.)/1866/1600/1333/1066 MHz memory modules (Note 2)
Audio
- Realtek ALC889 codec
- High Definition Audio
- 2/4/5.1/7.1-channel
- Support for Dolby Home Theater
- Support for S/PDIF Out
LAN
- 1 x Realtek RTL8111E chip (10/100/1000 Mbit)
Expansion Slots
- 2 x PCI Express x16 slots, running at x16 (PCIEX16_1, PCIEX16_2) (Note 3)
- 2 x PCI Express x16 slots, running at x8 (PCIEX8_1, PCIEX8_2) (Note 4)
- 2 x PCI Express x16 slots, running at x4 (PCIEX4_1, PCIEX4_2)
- (All PCI Express slots conform to the PCI Express 2.0 standard.)
- 1 x PCI slot
Multi-Graphics Technology
- Support for 2-Way/3-Way/4-Way AMD CrossFireX™ and NVIDIA SLI™ technology
Storage Interface
South Bridge:
- 6 x SATA 6Gb/s connectors (SATA3_0~SATA3_5) supporting up to 6 SATA 6Gb/s devices
- Support for SATA RAID 0, RAID 1, RAID5, RAID 10 and JBOD
- 2 x Marvell 88SE9172 chips:
- 2 x SATA 6Gb/s connectors (GSATA3_6, GSATA3_7) supporting up to 2 SATA 6Gb/s devices
- 2 x eSATA 6Gb/s connectors (including 1 eSATA/USB Combo connector) on the back panel supporting - up to 2 SATA 6Gb/s devices
- Support for RAID 0 and RAID 1
USB
South Bridge:
- Up to 14 USB 2.0/1.1 ports (8 ports on the back panel, including 1 eSATA/USB Combo connector, 6 ports - available through the internal USB headers)
- 2 x Etron EJ168 chips:
- Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header)
- IEEE 1394 VIA VT6308 chip:
- Up to 2 IEEE 1394a ports (1 port on the back panel, 1 port available through the internal IEEE 1394a header)
Internal I/O Connectors
- 1 x 24-pin ATX main power connector
- 1 x 8-pin ATX 12V power connector
- 1 x PCIe power connector
- 8 x SATA 6Gb/s connectors
- 1 x CPU fan header
- 2 x system fan headers
- 1 x power fan header
- 1 x front panel header
- 1 x front panel audio header
- 1 x S/PDIF Out header
- 3 x USB 2.0/1.1 headers
- 1 x USB 3.0/2.0 header
- 1 x IEEE 1394a header
- 1 x Trusted Platform Module (TPM) header
- 1 x clearing CMOS jumper
- 1 x clearing CMOS button
- 1 x power button
- 1 x reset button
Back Panel Connectors
- 1 x PS/2 keyboard/mouse port
- 1 x optical S/PDIF Out connector
- 1 x coaxial S/PDIF Out connector
- 1 x IEEE 1394a port
- 7 x USB 2.0/1.1 ports
- 2 x USB 3.0/2.0 ports
- 1 x eSATA/USB Combo connector
- 1 x eSATA 6Gb/s connector
- 1 x RJ-45 port
- 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line - Out/Microphone)
- I/O Controller
- ITE IT8720 chip
H/W Monitoring
- System voltage detection
- CPU/System temperature detection
- CPU/System/Power fan speed detection
- CPU overheating warning
- CPU/System/Power fan fail warning
- CPU/System fan speed control (Note 5)
BIOS
- 2 x 32 Mbit flash
- Use of licensed AWARD BIOS
- Support for DualBIOS™
- PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b-
Unique Features
- Support for @BIOS
- Support for Q-Flash
- Support for Xpress BIOS Rescue
- Support for Download Center
- Support for Xpress Install
- Support for Xpress Recovery2
- Support for EasyTune (Note 6)
- Support for Easy Energy Saver
- Support for Smart Recovery
- Support for Auto Green
- Support for ON/OFF Charge
- Support for Cloud OC
- Support for 3TB+ Unlock
- Support for Q-Share
Bundle Software
- Norton Internet Security (OEM version)
Operating System
- Support for Microsoft Windows 8/ 7/ Vista/ XP
Form Factor
- E-ATX Form Factor; 30.5cm x 26.3cm
Only £199.99 inc VAT.
ORDER NOW
Specification:-
CPU
- AM3+ Socket:
Chipset
Memory
Audio
LAN
Expansion Slots
- 1 x PCI slot
Storage Interface
South Bridge:
USB
South Bridge:
- 1 x power button
- 1 x reset button
- 1 x RJ-45 port
- I/O Controller
- ITE IT8720 chip
H/W Monitoring
BIOS
- 2 x 32 Mbit flash
Unique Features
- Support for @BIOS
Bundle Software
Operating System
Form Factor
ORDER NOW
