The sizing is a bit odd, but apparently that's just how the Merckx frames are measured. Bikeradar.com reviewed the 2011 model and noted the difference in sizing, I guess you have to be careful and try it out before you buy. It looks like a great spec for the price, and the 2012 Tiagra is a decent groupset from what I've read, especially now that it's 10 speed.I've just bought an Eddy Merckx AMX-1 for £600 from Winstanley Bike. It's a 2012 model with 10 speed tiagra groupset and shimano RS10 wheelset. Reduced from £1000.
I thought it was pretty good for the price, might be worth looking at. Note though that the sizing is a little funny. Im roughly a 58 on most bikes, I'm a 51 on this
Which bar tape did you go for in the end? The tape I have on my Van Nicholas is looking shabby now - the writing has worn off in places, and not in others, so I think it's time to replace it. The Cinelli gel tape is highly rated and is pretty cheap, so I was considering giving it a try.Anyone recommend some super padded bar tape? Looking to replace mine and I use some Deda stuff at present but I've really been feeling the road lately and I'm not sure if its because the tape is old or if its just not padded enough.
Although "steel is real", for a touring bike what you really want is titaniumTouring bikes: am I best of going for steel rather than aluminium?
