Sponsored by
So now I'm now looking at starting some of the paint work, Luckily I have a family member that is a professional paint sprayer and he's agreed to help with the paint. I was originally going to get this airbrushed but the cost is ridiculous for what I want.
With all the sanding done it was time to fill any unwanted holes and stuff i didn't like. I used a flexible plastics filler it doesn't have a very long working time and had to do this in three batches, yes it sets that quick.
It's applied the same way as any other filler
and sands down really well
I made a makeshift spray booth in the shed. This is ample for laying down some primer and the final coats will be done in the family members booth.
The panels were wet sanded between coats
wiped down with white spirit and tack cloth.
After 3 coats, I applied some satin black onto the belly pan, The satin paint is very easy to get a good finish with. The gloss coats for the other panels will be done by the professional sprayer.
The logos will be applied and lacquered in and that is the belly pan complete
I sat here spamming F5 as you were posting didn't want to post because of the chain break
