Anyone using the dark themed playstore and got a link to it?
Was linked earlier in the thread
Thanks benjo.Was linked earlier in the thread
Play Store needs to be flashed in recovery. Either delete Phonesky.apk or Vending.apk from system or just make sure it’s named Phonesky.apk in system/app first. Also, uninstall updates via system settings/apps to make sure it uninstalls the OTA updated version sitting in data/app.
Thanks benjo.
Do I literally just flash it via recovery? or is there more to it?
EDIT: Found it
Yep looks like it.
What rom are you on by the way?
Project Nemesis by CyanogenMod team turns out to be their new camera app:
http://www.androidcentral.com/cyanogenmod-focal-camera-app-nemesis
Looks really good and can't wait to try it out if the apk will work on non AOSP ROMs.
Somehow got it to work - pulled it from the system apps on FoxHound. Looks so
Had to uninstall updates via manage apps for it to work.
VS the fugly one that you linked benjo
I'm on PAC Man, SGS4.
What doesn't work (fixes being worked on)-
-Double-flick wrist gesture to launch the camera anytime.
-Panorama mode currently crashes. (It seems to be missing a required class, and I'm not sure whether we'd be able to fix it or not. If we can, I'll post an updated APK. For the interested, the error log is here.)
-HDR mode is disabled and cannot be enabled.
-Slow-motion mode is disabled and cannot be enabled.
Any chance you can share that apk on Dropbox or something? Looks pretty cool!
Was only a matter of time!
Galaxy S4 touchwiz air call feature
Motorola droid/X camera app
Not tried either of them yet.
Nexus, which 3rd party camera app do you recommend as you know I'm running AOSP on the S4 and it doesn't do 16:9.
 But for "overall", snap HDR and camera zoom fx are my preferred camera apps
Unfortunately not.
and yes to the second question.
But these 3rd party camera apps can sometimes produce better quality photos than the stock camera app and most importantly has way more options/features which is where the stock camera app lacks big time.
I am not exactly sure how it works, originally I thought it was tied to not only the camera app but also the sense/touchwiz framework/system but then Benjo posted saying that the touchwiz GS 3 camera app works on AOSP ROMs now and the quality remains the same so not sure why other developers can't do the same for htc devices (main reason for the one series phones is probably because of the dedicated image chip that does a lot of the processing) and gs 4 etc.
I am 90% sure that the GS 4 does have slow motion recording
