Nope, nope and nope
[IG]
http://i932.photobucket.com/albums/ad167/nuvpal/KGrHqR_rIFHDk2S40iBR5_kTvjQ48_80JPG.jpg[/IMG]
[IG]
http://i932.photobucket.com/albums/ad167/nuvpal/T2eC16VHJHYFFkOpGl-qBR5_YLVDzQ48_80JPG.jpg[/IMG]
[IG]
http://i932.photobucket.com/albums/ad167/nuvpal/KGrHqJ_o4FHFU5mrPJBR5_zsKWQ48_80JPG.jpg[/IMG]
[IG]
http://i932.photobucket.com/albums/ad167/nuvpal/KGrHqV_lEFHVrvuez_BR5_ZVqtoQ48_80JPG.jpg[/IMG]
Ad pics, I'll get her cleaned up and take some proper ones at some point.
125k on the clock - engine is still strong, gearbox is seriously solid! Bodywork looks amazing, 2 little dings noticed so far, that's it
Problems:
Diff is vibrating, quite badly sometimes - but supplied with a new diff so will get taht switched over this week.
Indicators for some reason don't work, he said they stopped when his other half was using it a couple weeks ago - hopefully not a major issue, but it's a BMW so I don't think they're required anyway
Small hole in exhaust.
I think after a good service (oil change, filters plugs etc.) she should be noticeably more powerful, currently only getting the full surge at 4k and above. Change the diff, fix the indicators, reconnect the ABS or fit some brembos and then she should be good for another 125k
Came fitted with 17" winter tyres (michelin), and then the 18" alloys loose with summer tyres (contis).
All for 1500
