That's interesting they are suggesting that the 9970 will have a 512 bit memory bus, so we get to have the arguments all over again with 384 not being enough![]()
512-bit memory bandwidth would imply an "all out performance" card. A 512-bit memory bus is tricky to work with efficiently, and leads to increased manufacturing costs. Not something that's going to be a popular route unless it's absolutely essential.
Besides, that entire link smells of BS. 4096 SP? Not likely. Not likely at all. Without some massive change to the nature of the shader pipes, a 4096 SP GPU would be really huge (at least 500mm^2), and I can't see AMD going down that road right now. That's a monster chip to produce so late in the 28nm cycle, for such a small market. I expect the 9970 to be about 2560SP, 384-bit, 3Gb (perhaps with a 6Gb version available), and to be about GTX780 performance or thereabouts (clock speed will determine exactly where in the 780 -> Titan performance spectrum it lands).
Those specs are not realistic until 20nm arrives. Even then - a 512-bit memory interface would be a drastic move.
