- 26 Apr 2004
- Wrexham
fairly sure we have a cake pop maker in the cupboard, never used. That and the bread maker would be high on the list!
Loads of place sell casings.
http://www.sausagemaking.org/acatalog/Hog_casings.html
Maybe in the UK but not so easy in the US,a nd I don't really want to buy online. If I am in the mood to make sausages I want to make them the same day. With my lifestyle it is impossible to plan ahead like that.
Plus the grinder has all the other hassles of kitchen equipment - it is a pain to clean.
I have a stupid big wok that I keep meaning to get rid of and getting something better..i thinks its a 36cm one!
any recomendations?! 28 or 30cm should be fine
I haven't managed to break this one yet, usually do. The way the metal is shaped leads me to believe it will last, you can't really see from the pic but there's a stamped "basket" that sort of sits in there. They had them in store.
http://www.tesco.com/direct/go-cook..._cmp=ppc_g__&gclid=CLPo89KCxLgCFfQetAodWAQAtQ
I've broken that one, the plate that pushes on the garlic to crush it has fallen off.
Enough about bananas already. Jesus.
food dehydrator from lakeland. Used once paid £50 - taking up loads of space
Aeropress.
Never use any of them.
My Imperia pasta machine came with a g clamp. Do you mean you don't want the material of your table damaged? But a piece of wood, or whatever, between the clamp and the table to protect it?
