Btw mate, i see you have the gigabyte Z87 oc board, ive got a 4770k coming this week. Looks like a nice board, kinda stuck between it and the asus maximus VI hero. Id appreciate your findings/opinions. Sorry to take the thread of topic.
I've just replaced a faulty Maximus Gene with the OC. Not had enough time with it, but it seems to be about the best ATX board under £200.
Ah sorry i didnt know that aa was better there is couple to pick from and i just left that as it was. What is the difference between them? And i guess you learn thing new every day . well i guess i will try it with aa onsee what happens
FXAA is just a filter applied, so it's easy on the GPU - but most people find it looks worse than regular AA (MSAA, SSAA, etc.) High AA settings at high resolutions will kill even the best GPU framerates.
Getting back to your question though, 2x670s is probably a bit excessive for 1080p gaming since, as you've found, you can lower AA settings etc. to get good framerates on one card in the most demanding games. If you really want a 144Hz display then some games would benefit from two, but it's a lot of money for one screen at that resolution.
