** LOGITECH - BACK AT OCUK **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
After a long period of absence, I am delighted to announce that the Logitech gaming peripheral range is back at OcUK.
Logitech have been through a lot of changes recently and their focus on gaming peripherals is higher than ever. Recently the new range of peripherals was launched and was unavailable in the online retail sector until now.
Overclockers UK are working closely with Logitech to ensure that you have the very best peripheral products available to you on our webstore
Our range is due to hit our warehouse next week but you are able to pre order over the weekend.
Here are a selection of the awesome products we sell:
Logitech G110 Illuminated Gaming Keyboard (920-002241) @ £49.99 inc VAT
Ready to step up your game? The Logitech® Gaming Keyboard G110 gives you what you need to customise your setup, communicate more effectively and execute complex commands easily. Locate the correct keys – even in the dark – with backlighting colours you can select and assign. Strategise with teammates and trash-talk enemies using the integrated USB audio. Configure up to 36 single keypresses or complex macros per game on the programmable G-keys. Use the MR key to record new macros on the fly. Connect your gaming mouse or flash drive to the Hi-Speed USB 2.0 hub port. Your game won't be interrupted until you're ready to call it quits, by disabling the Windows Context Menu keys with the game/desktop mode switch.
- Custom Colour backlighting
- Intergrated USB audio with seperate headphone and microphone jacks
- Twelve programmable G-keys with 3 macros per key
- High Speed USB 2.0 Hub built in
- Enable/Disable Windows/Context Menu Buttons with the flick of a switch
- Windows XP / Windows Vista / Windows 7 Compatable
- Removable Palm Rest
- Intelligent Cable Management
- One Touch Media Controls including volume control
- 2 Year Limited Warranty
Only £49.99 inc VAT.
ORDER NOW
Logitech G510s Gaming Keyboard (920-004976) @ £99.95 inc VAT
G510s includes 18 programmable G-keys that make complex actions simple by allowing you to configure up to 54 unique functions. Extend your cockpit to include less critical mission intel with the GamePanel LCD. Custom backlit keys allows you to assign a unique color to each profile, profile mode and mode style in the same game.
In gaming, the response time of your hardware can be the difference between a frag or a death, with a response time of 500hz (2ms) you know you'll be ahead of the competition.
With high-intensity backlight keys playing in the dark has never been easier and more unique, customisation is the key and logitech have not let themselves down with a varition of RBG colours.
Features:-
- 18 Programmable G-Keys allow you to configure up to 54 different gaming functions across 3 modes with 3 macros per key
- Gaming sessions can be long and tiring, so its best to play the comfortable equipment, the Logitech G510s a hydrophobic coating that prevents hand and palm stick while the double UV coating on the keys
ensure them long gaming sessions can be effortless.
- Integrated USB audio gives the ability to connect your audio system directly to the keyboard giving you full control over both the microphone and audio.
- LCD GamePanel giving you the ability to display real-time game stats, system information and VoIP communcation data.
- Six-Key Anti-Ghosting During the heat of battle, there are times when you might need to simultaneously run, strafe, select a weapon and open a door. Multi-key input on the G510s means complex moves are executed exactly right every time. Press up to six keys at once.
- Game Mode Switch You’re about to record a record high number of perfect headshots when an accidental keystroke sends you on an unplanned, unwanted trip to your desktop. Don’t let this kind of mistake ruin your streak or your game
Specification:-
- 18 programmable G-Keys
- Custom-Colour RGB backlighting
- Gamepanel LCD
- Full size UK Layout Keyboard
- Media Control Keys
- Keyboard Palm Rest Incl.
Only £99.95 inc VAT.
ORDER NOW
Logitech G19s Gaming Keyboard (920-004992) @ £179.99 inc VAT
Gaming-grade keyboard with a full-color GamePanel™ LCD for viewing critical in-game data, system status and more. 12 G-keys allow for up to 36 separate programmable functions per profile. The custom-color backlighting makes identifying active profiles a snap.
Features:-
- Adjustable, Colour Gamepanel LCD
- Custom-Colour Backlightning
- 12 Fully-Programmable G-Keys
- Advanced Surface Materials
- Two Hi-Speed USB Ports
- Game Switch Mode
- Public Software Development Kit (SDK)
- Onboard Memory
- Dedicated Media Controls
Specification:-
- Part Number: 920-004992
- Warranty: 3-years
System Requirements
- Windows® 8, Windows® 7, or Windows® Vista
- Available Hi-Speed USB port
- Internet connection for optional software download*
Package Contents
- Keyboard
- Palm rest
- User documentation
- AC power adapter
Only £179.99 inc VAT.
ORDER NOW
Logitech G230 Stereo Gaming Headset (981-000540) @ £59.99 inc VAT
G230 delivers high-quality stereo sound to keep you immersed in your game from start to finish with earpieces designed to be slim and light, without skimping on audio quality. We covered the G230 ear cups with carefully selected sports performance cloth for a comfortable, soft touch even after hours of use.
Features:-
- Game-Quality Stereo Sound
- Sports Performance Cloth Ear Cups
- Lightweight Design
- Folding, Noise-Cancelling Mic
- On-Cable Controls
- Lay-Flat Earpieces
Specification:-
- Part Number: 981-000540
- Driver: 40mm
- Frequency response: 20Hz-20KHz
- Impedance: 32 Ohms
- Sensitivity: 90dB SPL/Mw
Microphone Pickup pattern: Cardioid (Unidirectional)
- Type: Pressure Gradient Electret Condenser
- Frequency response: 50-20KHz
- Sensitivity: -40dBV/Pa re: 0dB = 1 Pa, 1KHz
- Test conditions: 3.0V, 2.2K Ohm
- 3-year Limited hardware warranty
System Requirements
- Windows® 8, Windows® 7, or Linux® operating system
- Headset and microphone inputs
Package Contents
- Headset
Only £59.99 inc VAT.
ORDER NOW
Logitech G430 Surround Sound Gaming Headset (981-000537) @ £69.95 inc VAT
In-game sound isn’t an effect. It’s a critical component of game play. Logitech G430 USB headphones give 7.1 surround giving you all the information you need. The sound is crisp and clear, and the jack on your sound card stays open for desktop speakers.
Features:-
- On cable controls
- Dolby Headphones 7.1 Surround Sound
- Full-Speed, All Digital USB
Specification:-
- Part Number: 981-000537
- Driver: 40mm
- Sensitivity: 90dB SPL/mW
- Microphone Pickup pattern: Cardioid (Unidirectional)
System Requirements
- Windows® 8, Windows® 7 or Windows Vista® operating system
- USB port
- 7.1 Surround sound requires software installation*
Package Contents
- Headset
- USB adapter
Only £69.95 inc VAT.
ORDER NOW
Logitech G27 Racing Wheel - PC / PS2 / PS3 (941-000093) @ £264.95 inc VAT
A simulator-grade racing wheel, the Logitech G27 Racing Wheel is designed to deliver the definitive sim racing experience for the PC and Playstation 3. Its powerful, dual-motor force feedback mechanism with helical gearing smoothly and accurately simulates traction loss, weight shift and road feel, with exceptionally quiet steering action. The six-speed shifter with push-down reverse gear allows you to quickly choose exactly the right gear. New RPM/shift indicator LEDs let you know when you should shift gears; the 28-cm leather-wrapped rim provides hours of comfortable, true-to-life racing; and steel accelerator, brake and clutch pedals deliver precise control for heightened realism.
Features:-
- Dual-motor force feedback mechanism with helical gearing
- RPM/shift indicator
- Sixteen programmable buttons plus D-Pad
- 900 degree wheel rotation
- Ultra-precise optical encoding
- Carpet Grip System
- 6 Speed Gear Shifter
- Steel gas, brake and clutch pedal
- Steel ball bearings
- Works with PC, PS2, PS3
Specifications:-
- Part Number: 941-000093
- Warrenty: 3 Years
System Requirements
- Windows® 8, Windows 7, Windows Vista®, or Windows XP
- 20 MB of available hard disk space
- USB port
- Internet connection for Software download
Package Contents
- Force feedback racing wheel Gas, brake, and clutch pedals
- Shifter module
- Power supply
Platform Compatibility
- PlayStation®2 computer entertainment system
- PlayStation®3 computer entertainment system
- Games that support Logitech® force feedback racing wheel
Only £264.95 inc VAT.
ORDER NOW
Logitech G400s Optical Gaming Mouse (910-003426) @ £49.99 inc VAT
G400s features exclusive Delta Zero sensor optimizations for high-accuracy cursor control. We applied specialized materials to each zone for improved comfort, control and durability. Mechanical microswitches are rated to a 20 million click lifespan. Low-friction polytetrafluoroethylene feet are tested to last an amazing 250 km.
Features:-
- Delta Zero Sensor Technology
- Ultra-Durable build
- In-Game sensitivity switching
- 8 programmable buttons
- Sculpted comfort grip
- 1-mMillisecond resport rate
- Slick feet
- Easy-to-use setup software
Specification:-
- Part Number: 910-003426
- Buttons (Left / Right / Third): 20 million clicks
- Resolution: 200 - 4000 dots per inch (dpi)
- Image processing: 5.8 megapixels/second
- Max. acceleration**: 25G
- Max. speed: up to 70-140 inches (4.06 meters)/second*
- USB report rate: Up to 1000 reports/second
- Dynamic coefficient of friction***: .09 µ (k)
- Static coefficient of friction***: .14 µ (s)
- Total weight: 133 grams
- Cord: 15 grams
Package Contents
- Mouse
- User documentation- Durability
ORDER NOW
Logitech G500s Laser Gaming Mouse (910-003604) @ £59.99 inc VAT
G500s features hyper-fast, dual-mode scrolling. You can adjust for feel and performance with up to 27 grams of extra weight. We applied advanced materials to each zone for improved comfort and durability.
Every task demands a specific style of play, and every gamer has a distinctive style. Some mice, like the G500s, let gamers adjust the weight for the task at hand—like, say, flying a quadrotor through an obstacle course. Our gamers learn that an unsteady hand can lead to embarrassment.
Features:-
- Weight and balance tuning
- Dual-Mode scroll wheel
- Advanced surface materials
- In-game sentivity switching
- 10 Programmable controls
- Onboard memory profile
- Braided USB cable
- 1 Millisecond report rate
- Gaming-grade laser
- Slick feet
- Easy to use software
Specification:-
- Part Number: 910-003604
- Buttons (Left/Right): 20 million clicks
- Resolution: 200 dpi - 8200 dpi
- Image processing: 12 megapixels/second
- Max. acceleratio**2: 30 G
- Max. speed**: up to 165 inches (4.19 meters)/second
- USB data format: 16 bits/axis
- Dynamic coefficient of friction***: 09 µ (k)
- Static coefficient of friction***: 14 µ (s)
- Tuning weight: Up to 27 grams
Package Contents
- Mouse
- Adjustable weight-cartridge
- Tuning weights and case
ORDER NOW
Logitech G700s Gaming Mouse (910-003423) @ £89.99 inc VAT
G700s charges during play over its standard Micro-USB cable. Reassign any game command or multi-command macro to any one of 13 programmable buttons. G700s maintains a consistent 1 ms report rate, up to eight times faster than a standard USB mouse.
The more macro keys you have on your mouse, the more power you have in the palm of your hand. We put this theory to the test by having two gamers program their keys to their liking, and then use their mice to make lunch. Watch as the G700s, with its 13 programmable keys, is pitted against a comparable mouse.
Features:-
- Data Over Cable
- 13 Programmable Controls
- Consistant Report Rate, Wired or Wireless
- In-Game Sensitivity Switching
- Dual-Mode Scroll Wheel
- Plug and Forget Nano Reciever
- Ultra-Durable Build
- Slick Feet
- Intuitive Shape and Design
- Gaming Grade Laser
- Onboard Memory Profiles
- LED Display
Specification:-
- Part Number: 910-003423
- Warranty: 3-year Limited hardware warranty
- Max. acceleration**: 30 G
System Requirements
- USB port
Package Contents
- Mouse
- Wireless receiver
- Charging cable
- Receiver extender cable
Only £89.99 inc VAT.
ORDER NOW
I thought the Logitech range was looking a bit thin recently.
I wish they'd update the G13 with a colour screen, and mech keys.
Very nice looking keyboards. Did have a bash with a Razer recently and really enjoyed it and now that I've gone back to a basic keyboard I feel it's missing something. Maybe one of these Logitechs might be the answer
