Hi, would you be able to tell me how wide the stand is on this?
The stand at its widest part is 26.5cm
Lovely TV/monitor but i could never go back to 60hz after experiencing 120hz
To me its like night and day.
Huge difference in how smooth games move.
Hi sprouts sorry to hear about the light bleed.
makes sure in the picture settings " motion eye care " is off as this can alter
certain parts of the screen to go bright and dark, god knows why they do this.
after hours and hours of testing i went for the " vibrant " picture setting but turned the colour down to 65 and popped brightness to 45 and sharpness to 30.
hopefuly its the " motion eye care " thats made the left hand side bleed.
if not i spose you could complain to curry's and tell them you seen a friends set and it doesnt have this issue.
Well sadly mine did go back as the light bleed was too bad.
In real world use it is rarely noticeable but for an expensive TV (for it's size) I could not accept it
It is a shame as the picture quality was excellent.
Noticing some users comments on here about various processing rates (60 Hz 120Hz) etc; in my experience it mostly down to the implementation. i.e a well implemented 60 may be better than a poor higher rate. Also we all see things different
Don't let my experience put people off, it is a cracking bit of kit
As an aside, I could have picked one of these up in person at a Curry's 10 miles from my home, HOWEVER Curry's return policy for items bought from a shop can only be returned if unopened or faulty. OK, mine had a fault but that could have been a painful, subjective debate in a well lit store!
If ordered online for delivery you are covered by the distance selling regs and can return with ease![]()
I'm thinking of getting this, or the cheaper (same screen?) LG 27" 27MS53V, solely for TV usage.
I'll mainly be watching TV through it, but I also will be watching some Sky via a digitsender via the scart port.
Are you able to comment on :-
1) General TV (HD) quality?
2) The screen is matt and not shiny (reflective)?
3) What's the EPG and menu like? Quick? I know some TVs are very slow and clunky.
4) Have you fed in any analog sources? eg: A video recorder over scart or something? How did it fair?
5) The audio appears good on paper, 2x7w. I'm not expecting amazing things, but for a bedroom is the volume/clarity good enough?
6) Any other opinions/thoughts?
Thanks...
^^ Can you definately get to Netflix through it?
I had a look at one in a shop and was put off by the glossy screen, so preferred the cheaper model without the glossy finish. Unfortunately it has a black plastic version of the lovely stand, and no Smart remote![]()
We have window(s) on the opposide side of the room at just the same level as the TV will be, and prob the appropriate angle tooyes netflix and iplayer good to go. even a free trial of Nowtv powered by sky.
only you can judge how reflective screen will be in regards to position etc.
my window is behind the screen so its a none issue for me. i can have a light on above and theres no reflection though![]()
What do you think of the magic remote? (ie: My cheaper version won't come with it)
the magic remote is a god send and i couldnt use a tv without it now.
if the tv is in the bedroom i spose you could always close them almost shut while viewing. after all its a bedroom not a living room![]()
And using the magic remote from 7-8ft away? Practical?
very practical. it's easier infact.
Grrr! Damn you!
And what do you really use it for in practice (that a normal remote can't do sufficiently well)?
i thing i like to use it the most for is surfing the net in bed lol.
but even down to switching imputs as i use mine for pc monitor also or console.
this tv is up there with high end bigger screens but also manages to be a great pc monitor. it took me 3 years to find a good tv like this.
and it was worth the wait.
How far do you sit away from it when browsing (in bed)? Surely the text would be too small to see more than 4-5ft away?
