I'm very tempted to get this case but I am concerned about the dust filters. What filters are present and what would you buy if you needed extra?
I'm not keen on the holes at the bottom of the case!
Can I just confirm these are the best fans to replace the standard ones with in the case?
http://www.overclockers.co.uk/showproduct.php?prodid=FG-006-CS&groupid=701&catid=2331&subcat=1816
If so how many do I need and of what size as I see theres 120mm and 140mm versions. I don't get my case until Weds so can't look myself
Many thanks
Is anyone using the stock fans that come with this case...and if so what are they like for noise please ?
Thanks
Steve
Well, I've just finished putting a custom CPU waterloop into my 540 and that really was not easy or fun. I didn't think it was a particularly easy case to do a build in for air cooling, but with watercooling it's a real ball-ache. (Am I allowed to say ball-ache?)
I changed them. I found them to be a little noisy.
Ahh OK ...cos I put two of the stock fans back in at the top....and via BOIS put the fan profile to Silent they are running at about 650rpm and I cant hear them at all......I did have two Aerocool Shark 140s , and even on silent they are too noisy
