- 10 May 2012
- North London
Nice build Yerman
nice cooler too
i have the black one
nice cooler too
I think so too
But I dont know enough about them to know what not to waste money on lol
I'm probably going to make the jump and purchase this case. I've got a quick question however. All the cable's people have, are they looking the way they are because of the PSU being modular? My cables are all split etc, so I was curious.
Nice build Yerman
nice cooler too
My front USB 3.0 is fine. I have used it with 3 different motherboards now and it's been fine with each. It could be cable or motherboard. I guess probably not drivers if the device is working ok on the direct USB 3 ports.
Check the motherboard / lead for any bent pins would be my first advice.
Thanks for the advice, all the pins look fine to me. I'm guessing it's most likely the lead or front panel on the 540 that's faulty but impossible to say without trying another motherboard.
I've seen a few similar issues in the Corsair forums for other cases and they sent out replacement front panels so I might try contacting Corsair.
Thanks, yes it really is a great cooler, I'm quite surprised just how well it works.
I have a question for anyone with a 540 case.
Is anyone having issues using USB 3.0 devices connected to the front panel? When I connect my USB 3.0 external hard drive to the front panel it doesn't work and I get hundreds of errors in Event Viewer saying 'An error was detected on device \Device\Harddisk3\DR11 during a paging operation.'
If I connect the same hard drive to the USB 3.0 ports on the back of the motherboard it works fine with no errors. Also, if I connect a USB 2.0 device to the front panel that works fine, it's only 3.0 devices that give me errors.
I can't work out if its a physical problem with the case, a motherboard issue or a driver problem.
- Cables for front power button and lights are just a little too short. Could be position of connector on this board? Using the power switch on the motherboard at the mo - will have to look for extension cables, or lengthen the existing cables myself. Anybody else have this issue?
- Included fans are 3 pin type. Was hoping for 4 pin - my board doesn't control 3 pin fans that well. I have three G3 "golf ball" 4 pin fans I can fit if needed though. One of the fans is sounding a bit "buzzy" too - I think the rear one. Can confirm when I start swapping fans around.
- The accessory box was pretty low on bits. Surprisingly empty for such a small box. Could do with a few more screws, motherboard mounts, some spare thumbscrews etc. Unless they were just missing from mine?
We can send you a front I/O panel that has longer cables. Just submit a ticket at
Corsair.force.com and we can sort it out for you.
If one of the fans is indeed buzzing after you've tested them one at the time, then mention that in the ticket as well so we can replace it, considering that you'd be using the stock fans rather than an after market one.
Your box should include all of these screws;
http://www.spartantechreview.com/wp-content/uploads/2013/07/SDC10379.jpg
We can send you a front I/O panel that has longer cables. Just submit a ticket at Corsair.force.com and we can sort it out for you.
