Road Cycling Essentials
Status
Not open for further replies.
I would get a bike shop to do it.
I'll happily cut metal steerers with a pipe-cutter but i wouldnt cut a carbon steerer. I'd be too worried about cutting it squint or fraying the weave.
A normal hacksaw will go through carbon fine, so you could give it a go if you want to. Wear a mask though - carbon dust isnt nice.
A normal hacksaw will work but you should wrap the cut point inside and out with take to avoid splintering.
I used one of these: http://www.carbonmods.co.uk/Products/Perma-Grit-152mm-Rodsaw-with-Junior-Hacksaw__TC2.aspx
Does anyone have experience of Castelli bibshorts? What're your thoughts on them?
They do a wide range. The lower end is probably on par with cheaper DHB but the higher end stuff is excellent. (Progetto X2 pad). Sorpasso bib tights are awesome they're fleece lined for winter and almost entirely waterproof.
I prefer them to Rapha/Assos but I rate my 2XU bib shorts above all my others.
I've got some Castelli Bodypaint 2.0 shorts.
I've used them once and they were comfortable for 70mi, but whether they are better than shorts costing half as much I'm not so sure.
I plan to wear them for the 150 miler this weekend so I will reserve proper judgement until then.
Yep - got a pair of those. Mine are the Free Aero Race ones and they are very nice. Comfortable on longer rides, say more than 3-4 hours. I also have DHB ones and they are good too but not as comfortable beyond 3 hours. The pad in the Castellis is really good, the leg grippers are also better. I think I paid £85 for them and I would again.
what did you get?
Planet X Ti. Couldn't really stretch to any other and is a simple swap for nearly all my current components, the exception being the seat post. £900 for the frame, fork and new seatpost.
I asked my LBS and they will do it, but they said they are booked up for a couple of weeks now. :/
I've seen videos of it being done including wrapping it in insulating tape and it doesn't look difficult, but then they're experienced.... The only thing I'm missing is one of those guide tools, my LBS doesn't sell them so is it wise to do it without?
Excellent. Really excellent.
Thanks all.
So it seems that it is model dependent. How do these stand up in the £60-£75 range?:
http://www.ribblecycles.co.uk/sp/ro...t-ultimate-performance-bib-shorts/castzzbs105
http://www.ribblecycles.co.uk/sp/ro...stelli-velocissimo-due-bib-shorts/castzbbs147
[DOD]Asprilla;24849944 said:
I didn't use a guide, I used a load of cheap spacers.
That's a good idea thanks, I have loads spare so I'll probably do that.
The head tube on both frames is the same so it shouldn't be too much of an issue cutting it and I think my current fork's steerer is a bit too long so I've got a bit of wiggle room.
Well, my second days cycling was better than yesterday, beat a fair amount of segment times from yesterday (PR's not KOMs!!) so I am pleased with that. At least the curve is going upwards! Going to take tomorrow off and head out again on Saturday, just to rest my tired legs and neck a bit.
I think its vital when starting out road cycling to leave a day or two here and there for recovery, so that's the plan!
If you can afford it, go for a pair with the Progetto X2 pad, as it's the best one on the market (that I've found). The Kiss3 pad is excellent though and you won't regret it.
Oh yes and size up if you value your testicles.
Reminds me, I'm going on an advanced mechanics course next weekend. Should be interesting!
Where are you going to do that? Have you been on a more basic one in the past? I keep meaning to look into it, then I forget all about it until something goes wrong with one of the bikes.
There is a bike courier company here in Cambridge called Outspoken. Quite famous around these parts. They run courses every now and again.
And yes, I've done a basic and intermediate before.
Status
