I would get a bike shop to do it.
I'll happily cut metal steerers with a pipe-cutter but i wouldnt cut a carbon steerer. I'd be too worried about cutting it squint or fraying the weave.
A normal hacksaw will go through carbon fine, so you could give it a go if you want to. Wear a mask though - carbon dust isnt nice.
[DOD]Asprilla;24849785 said:Zipp 404s clinchers for £1,499 a pair at Merlin.
35% off.
Nice, only about 5 times as much as my entire bike is worth.
Does anyone have experience of Castelli bibshorts? What're your thoughts on them?
what did you get?
[DOD]Asprilla;24849771 said:A normal hacksaw will work but you should wrap the cut point inside and out with take to avoid splintering.
I used one of these: http://www.carbonmods.co.uk/Products/Perma-Grit-152mm-Rodsaw-with-Junior-Hacksaw__TC2.aspx
They do a wide range. The lower end is probably on par with cheaper DHB but the higher end stuff is excellent. (Progetto X2 pad). Sorpasso bib tights are awesome they're fleece lined for winter and almost entirely waterproof.
I prefer them to Rapha/Assos but I rate my 2XU bib shorts above all my others.
I've got some Castelli Bodypaint 2.0 shorts.
I've used them once and they were comfortable for 70mi, but whether they are better than shorts costing half as much I'm not so sure.
I plan to wear them for the 150 miler this weekend so I will reserve proper judgement until then.
Yep - got a pair of those. Mine are the Free Aero Race ones and they are very nice. Comfortable on longer rides, say more than 3-4 hours. I also have DHB ones and they are good too but not as comfortable beyond 3 hours. The pad in the Castellis is really good, the leg grippers are also better. I think I paid £85 for them and I would again.
Excellent. Really excellent.
[DOD]Asprilla;24849944 said:I didn't use a guide, I used a load of cheap spacers.
Thanks all.
So it seems that it is model dependent. How do these stand up in the £60-£75 range?:
http://www.ribblecycles.co.uk/sp/ro...t-ultimate-performance-bib-shorts/castzzbs105
http://www.ribblecycles.co.uk/sp/ro...stelli-velocissimo-due-bib-shorts/castzbbs147
Where are you going to do that? Have you been on a more basic one in the past? I keep meaning to look into it, then I forget all about it until something goes wrong with one of the bikes.Reminds me, I'm going on an advanced mechanics course next weekend. Should be interesting!
