- 8 Oct 2008
The
Now you can volt mod them to 1.3v that might be difficult (it makes buying a 780 lightning or classified a bit pointless) unless AMD want to come in at a higher price with a bigger chip.
It all depends which way AMD want to go.
It's got to match a stock 780 or AMD isn't going to bother. A new series with the top end graphics card that performs worse than nvidia's top end one (ignoring the Titan) would be terrible marketing. I think it'll be £350ish, £400 max.
It will definitely match a stock GTX 780 at the very least.
In my previous post I was referring to overvolting Titans with 1.3v which makes the new non ref 780 lightnings and classifieds a bit pointless now.
question is die size, if they go bigger like 470mm2 or so then it be a beast
why expensive ?
the GTX470 had a die size of over 500mm2
Bigger chips, lower yields
Nvidia only paid for functioning GPUs with the GTX400 series,not whole wafers.
Interested to see max OC GTX 780 VS max OC X970.. Can AMD really release a chip that can match an OC GTX 780?
I will be seriously impressed, check the pixel and texture fillrate below, can AMD really match / beat this?
It does not matter how NVidia pay for them, bigger chips equal lower yields equals more expensive chips.
It doesn't matter about that.
9850 = 7950 rebadge
9870 = 7970 rebadge
9950 = Hawaii 20nm >780
9970 = Hawaii 20nm >Titan
any chance of that?
