You done good, I would be about £600 better off if I smoked
http://www.puffin-eliquid.com/ukv/?banner=5032
Wrap the link in
I'm not doing too bad...
Prolly spent about £300 on kit n juice.
Hey guys. Been doing quite a bit of research today for my dad. Smoker for 30+ years and he wants to try out an ecig. I've been looking through some starter kits and came across this one which seems to be the most highly reviewed:
http://www.ukecigcabin.com/product/kanger-evod-starter-kit
The Kanger EVOD BCC Starter kit contains:
2 X Rechargeable Kanger Brand EVOD batteries 650mah
2 x Kanger Evod BCC clearomizers (for filling with e-liquid)
1 x Pack of 5 replacement spare coil heads for the clearomizer
1 x Usb cable for charging the batteries
Anyone tried this? Looking to spend £40 max, if anyone can recommend something better that'd be cool too.
Which one do you prefer out the two, what's the difference, both easy to recoil etc?
The magneto has a button on the very bottom which puts me off but all the bloody mech mods seem to have that. I have a feeling that'll be annoying vs the SVD....
I need to read up on drippers a bit more to understand the benefits of them.
Ithaka is looking good from there
maybe this then: http://www.fasttech.com/products/1411/10005273/1423000-private-v2-telescoping-mech-mod-e-cigarette
magneto looks far too scratchable!
this looks okay too...
http://www.fasttech.com/products/0/10005379/1429501-bagua-mechanical-mod-e-cigarette-battery
I have a Dingo Mech mod from Atmizoo and thats a side botton instead of a bottom button.
I know, I've had my eyes on your mod for a while debating whether or not to nab one. How have you been getting on with it or what have you had previously and has did this compare to them?
@Crowort, The ithaka is growing on me, as well as an igo L/W and a general tank mod to have on me to replace both of my iclear 30's when the heads die (can't be bothered to buy replacements heads for them and will sell them at that point).
The issue I keep running into is am I buying more than necessary and this i starting to cost a lot more than smoking (was costing me £7.00 a week).
I have an SVD, a backup cheapy ego (in case of emergency equipment malfunction and will stay in a drawer), two iclear 30's and a protank 1.
What I'm going to end up with:
4/5 atomizers (ithaka, igo w/l, rsst/atty mabob, protank, trident (maybe) )
Two units (SVD for home/office use and a tiny mod, bagua/dingo/something for out about use/nights out)
Do you guys limit your vaping at all?
I swear I've been vaping more than I used to smoke so am probably getting more nicotine.
Poldiac has a very nice magnetic side button
I'm having this problem. My mod never leaves my hand once I come home from work. I must going through about 2 tank fulls every night before bed. Funny thing is I used to be a light smoker, about 3 rollies in the evening.
I noticed that my vaping is affecting my sleep, I'm as high as a kite come bed time and can't sleep. I now get stressed about not being able to sleep and need to have a vape to claim down. Having about 3 bottles of Duvel helps me sleep, so need to stock up on a few crates.
My dingo has been nothing but good to me, I managed to remove the 510 connection ring in it by accident by not having it tightened properly so it got stuck to my Aga T2 but that was me being stupid.
The build quality is amazing its size is amazing, it looks GREAT with a MMvapours DID vapes great too.
If your looking for a side button mech mod and want something small in 18350form this is your device. I came from a Vamo to this so ive no previous mechanical mod experiance to compare with how ever its miles better then my Vamo..... I only use my vamo to measure ohms now lol.
I have a MMvapours DID a Aga T2 RBA and will be getting a Spheroid and a Zap soon to go along with them.
Ive completely stepped away from Cartos and clearos.
I was thinking of trying an IGO W or L but i cant be bothered at all to drip![]()
I'm an avid shisha smoker, and was looking into vaping. The only thing I am worried about is the restriction and lack of deep tokes /drags. Most I have used have been very restrictive and burn too hot to be able to deep toke them.
I'm also a person where if I am to do something, I will try to do it best, no beginner products, straight in for the kill with the topeend stuff, and after getting it worry about how to make it work
Is there a general link or direction I should be looking? Should I jump straight into mechanical mods and atomiser rather than the camp and protank?
OK guys, it's question time, I'm afraid:
I have 2x Apollo VVs and 1x Kanger Protank (I recloil them myself now) and 1x Vivi Nova. I tend to use the Protank as it's better now I've fixed all the leaking issues and taped 2 of the air holes:
I'd like to change the batteries at some point, but I'm loathe to spend 150 quid (or whatever) on a Provari. Ideally, I'd spend nothing, but I don't think the Apollo is really good enough for my requirements (I vape almost exclusively these days). Could definitely find 100 quid (preferably less) but it would need to be significantly better than what I've got now (i.e. not just more shiny with better build/longevity)
Any suggestions that are different to the Provari idea? Vamo perhaps? Anything better than a recloiled Protank 1 for me?
I feel demanding, but there's a lot of knowledge here![]()
