I plotted this route.
Couple of lumps in the middle. One of the highest A-roads in Britain, that sort of thing![]()
There's an official route? When I was the lakes recently it was all signed up "C2C"
about the same climb as my ride on sunday. that's only 116km tho.
really, you guys should come to cornwall. everywhere else is flat.
http://ridewithgps.com/routes/3279795
on this note, talk to me about CO2 inflators, mini pumps and puncture repair kits
are they worth it, are they all crud, do the self adhesive ones work? respectively.
On another note...my quads are ******* killing me!
I get turn prompts PRIOR to the turning rather than when you are on top of it by using ridewithgps, take out any left/right/straight on cue sheet entries i dont want then export it to my PC as a TCX.
Then in bikeroutetoaster import the TCX and export it as a TCX with a turn warning set (i set turn warning distance to 300ft). It bleeps as a turn warning so you know you have to turn (it bleeps again usually when you've made the turn!).
Note that you can just leave it on your normal speed/time/distance/whatever screen and the turn prompts come up with an accompanying bleep.
how long did it take you to do the 116km?
Really annoyed this morning as I lost a cleat screw and as I unclipped, one of the screw holes collapsed out of the sole and now I can't screw the cleat back in.
Looks like a good route to me.I plotted this route.
We're all road cyclists. Of course it would be okI'd be in. Is the route ok for road bikes. My mrs did a C"C earlier in the year but is was across all sorts of terrain so she used the MTB with semi slicks.
Then get pedallingI'd be in, but I'd have to work really hard to get anywhere near you guys!
Yeah and as for getting back well, there are some options:Looks awesome, I'd be in if a few from down south fancied trekking up north![]()
Are you using SPD-SL?
How do you mean, the screw hole collapsed?
Not properly. It just plots a line which you follow. Its good for the most part until the road forks and you're unsure which road to take. Or it can update the display as you're approaching a turning. In doing so it clears the map and its very easy to miss it. But it gets you from A to B.
