Road Cycling Essentials
Status
Not open for further replies.
Is £15 + postage reasonable?
This is of course subject to the 80mm stem not causing me to crash in a horrific way due to twitchy handling!:D
Yeah from what I've read it's not as bad as people make out and you soon adapt.
I think it will improve my comfort quite a bit by reducing the reach slightly.
I've been thinking about shortening my stem recently actually. Since moving my handlebars down I feel like I'm reaching more (obviously).
I went from a 110mm stem to a 90mm stem, I can't say I've noticed a difference in how the bike handles. It's a lot more comfortable, however. Combined with rotating the handlebar slightly, I'm now able to ride on the drops almost all the time.
I'm an 80mm user as my arms are short :p
Moved from 100mm on the Tarmac to 80mm on the Domane, you get used to it!
I never used to think my arms were short, but I think I am. The Rapha jackets for example are a perfect fit in every way, except being about an inch to long on the arms. It's weird.
I've never paid more than £15 for a stem!
Yeah I've spent up to £30 before but even I think more than that is silly money really.
The FSA OS-99 is £120 and 122g for example, compared to the Deda Zero1 which is 133g and...£18.99 (100mm size). I cannot understand how 11 grams is worth £100.
And I think I'm definetly a bike tart but spending silly moneys on stems... no thanks! :)
Got the fast wheels on the shiv now!
But you buy Rapha clothing which is silly money! :p
:o This is true!
However, there is a noticeable difference between clothing manufacturers such as Rapha, Castelli and Assos (my three of choice) and cheaper ones. Whereas - convince me the FSA is worth £100 - yes 566.6666666666667% more for eleven grams?!
Screw you! :p
Nah, I'm not bothered how it looks in all honesty. I bought it for speed only. However to me it looks nice enough anyway and goes like stink - the important bit! It actually holds 750ml of fluid in there too.
I agree that an expensive stem adds zero performance gain, but I refuse to have any stem other than the 3T ARX Stealth to go with my 3T bars. :P
Status
