*** The Official Samsung Galaxy S4 Thread ***
Anyone having an issue with Nova Launcher where no matter if you set it to be the default launcher sometimes you get the popup asking which launcher to use and always/just once.
If you're rooted just use something like titanium to freeze the other launchers then you shouldn't have a problem.
Kona, you'll be happy to know that the blue bar in the settings app has changed to black in the latest PAC release heh
:D
edit - could you post a screen shot pls bud?
So how are you getting on with PAC Man 4.3, James?
On my s4 when I press apps its the same background as the main phone screen. Is there a way to change this so its a dark colour? as I have issues seeing the name of the apps (I am reg blind.) :)
What is the latest baseband version I am running MF8 i am guessing this is out of date now?
Also when i did the baseband update via Odin i noticed i stopped receiving notifications from my emails. I have to go into my email and sync even though i am setup to do this every 15 mins.
Any help I would be grateful.
Screenshot
How am not finding it. Great to be honest. Focal is still rubbish but otherwise top banana. It has new sliding animations that weren't there before. Had distortion issues with the bundled DSP but installing viper4android fixed that and then some. Battery life is as good as expected. Liking it a lot :)
I honestly can't remember if the stock launcher does it, but other launchers like nova and apex do and they both have free versions available on the play store :)
I would highly recommend Nova, especially because it has a lot of features that will be useful for you :)
makes sense, this is in response to security concerns.. android is much less secure and the fact we all root and hack and flash and then try running banking apps perhaps points to the necessity for this.
Can't have it both ways I guess!
Glad Natwest don't block rooted phones! One good up for them! :D
People kicking off over at XDA about the new update. It sounds like Samsung have become more aggressive in locking down the system with it including;
  • Blocking root
  • Changes the SELinux from permissive to enforcing (someone care to explain that)
  • Read only system
  • Constant 'Prevention information' errors about apps
  • Custom launchers are messed up because of the new permissions
It may be in preparation for KNOX. Some are even saying they are going to change to Sony if this continues - can't be said lightly ;):p
Worth mentioning if you update to MGG/MH8 you'll have flashed a locked bootloader and can't go back and downgrade (as of now). And that included your nandroids.
No one?
  • Blocking root
  • Read only system
Sounds like a great update :D
Glad I'm already rooted.
Screenshot
Liking it a lot :)
Nice, just the way I like it :)
Awesome.
Cheers.
I disabled the sliding animations straight away... they just really annoyed me.
Did you do that in dev option, so know you have no animations at all?
If you force JB app animation in Nova does that change it?
Yeah it was in the Dev Options, and I realised that but I just couldn't stand the windows flying around, lol.
I just tried the Nova options set to JB and it made no difference whilst the animations were disabled. I put the setting back to 0.5x and it seems to have done the trick. Thanks for that :)
