Used some Turtle Wax Interior 1 carpet cleaner on the front seats to get a few marks off. Wasn't hoping for much as I'd already used some house hold stuff, but it worked very well. I think the brush on the end helped the most.
Cleaning a windscreen with a razor blade? Anyone tried that?
He definitely is a touch obsessive (just another few sprays...) but generally his videos seem useful.
Anyone have any suggestions for a good easy to use wheel protector?
I've used Bilberry to clean my wheels, but I'm picking up a car with nice new clean wheels this week, so I'd like something I can spray on the alloys to make future cleaning a bit easier. As the wheels are almost brand new, they shouldn't require too much, so the easier to use, the better.
Give your screen a good claynormally helps with bugs too
Would a bottle do a whole car?
I have those annoying car wash swirls all over. None are deep but every inch has them!
Hello, I've started to get into cleaning my car properly this past year, I wouldn't call it detailing just yet but its getting there. Anyway I think I'm getting to the point where a good machine polisher would be very helpful. Last week I washed the car with 2BM, Clayed it, treated it to some poorboys black hole by hand, then 2 coats of nattys red by hand, then a quick clean of the wheels and tyres. This took the best part of 3 hours and at the end my arms and shoulders where aching.
So what is a good machine polisher to get? Ideally I need a machine, pads and could do with some good polish both a high and low grit as some numpty has left some nice marks on my rear wheel arch in car park and I'd like to try and polish them out as best I can instead of calling the mobile paint shop out.
My budget is about £100 for the machine at the moment and can hopefully pick up some more pads down the line, obviously if I can get a cheaper machine and more accessories then that would be great.
