It costs more lol, otherwise noSo there's no downside to using one of these as a standard drive, stand alone in a PC?
Looking to upgrade one of my internal drives to a 3TB one, but I've noticed my preferred choice of Seagate Barracuda only give a 1 year warranty?
That worries me!?
Any suggestions/alternatives?
Western Digital Greens? - These only seem to have a 2yr warranty? And they seem to have quite a low RPM?
Not too bad... RED 3TB for £120, with 3yr warranty!
Only £20 more than say a Seagate one with a 1yr warranty!
That said the RED is only 5900 RPM!?
I would recommend the WD Red Drives they have a 3 years warranty and are designed to be used 24/7 so they are robust and reliable. I have two in my machine and they have been working flawlessly.
Depends on what you will be storing on there really if its just pictures, movies and music then the WD RED is ideal, if however you are looking to put your Steam account on there then I would say get a WD Black instead.
WD have just released a 4TB RED drive too so that might be worth a look should you want a little more space.
Well, its for my main (sole) hard drive, with a SDD being the OS drive. So my steam account for example will be on it.
That said, I'm looking to also get a USB caddie and start fully mirroring all my drives regularly (across all my machine). At the moment I just do important files, but I'm going to start doing full disk mirrors.
So maybe I'll get a BLACK as my main drive, and then a RED as the drive to store away as the mirror of it.
This would be my advice, the Black has that little more grunt and the Reds are much better suited to storage.
And the noise isn't an issue on the blacks? (Keep in mind, at the moment I'm on SATA2 with my MB)
I have had blacks in the past and that's never been an issue for me. SATA 2 wont really matter there will be very little real world difference with a mechanical drive.
There is a very big fly in the ointment and that's how Windows sees drives over 2.19TB especially if you want to boot from it. Mac OS X or Linux users have no such problems but if you using Windows then you are faced by a couple of constraints.
First off you need a motherboard with a UEFI (Unified Extensible Firmware Interface) BIOS, like the new Sandy Bridge boards. There are a few around but they are by no means common and you need a 64-bit OS (Vista or Windows 7) and one that will create and use GPT partitions.
If you decide to get Western Digital drives you can add another years worth of warranty to the drive by purchasing a " WD Care Extended Service Plan ", cost about £5.99 though Ocuk does not sell it but you can get it from a competitor, saying this Ocuk should really make this available on there site as £5.99 seems a pretty reasonable price for another year of warranty.
Never heard of this but sounds very good and definitely seems worrth it.
It doesn't make the drive any more reliable, just you get a bigger window where if it fails, you get a replacement free.
This true?
I'm now thinking of getting one of the Seagate Barracuda 7200.14 2TB drives (1tb platter, 2yr warranty).
Half the price of the Western Digital Black and supposedly faster, quieter and cooler!
Bear in mind I have the OS on a SDD, and the plan is to back up both the SSD and my new hard drive entirely every few months, so if a drive fails I've got a recent backup!
Thank you demon, I've been waiting for that news for an absurd length of time.
The speed isn't a big worry really - my WD green drives have no problem sustaining 100 mbyte/s for large transfers. The higher speed drives will be better at small file accesses, but the popular combination of ssd + hard drive wipes out that advantage.
