Cross chaining big/big the chain skips up on top of the front chainring every couple of rotations.
...dont ride in the big/big then
Anyone for a new Ultegra groupset? Have stuck mine on bikeradar, didn't fancy the lever shape which is a killer really![]()
The progression through the gears just feels more natural to me on the double. On the compact my favoured gears seem to sit at awkward/extreme chain positions and shifting doesn't feel progressive as I have to down-shift the rear as I up-shift the front.
Hmm has anyone moved from a compact to a double? Experiences?
If you need to replace your chainset for whatever reason, you might want to consider a standard. If it doesnt need replacing, then I dont think that the benefits of swapping to a standard are worth the cost.
I don't do a big commute (it's actually small enough that I won't mention distance for fear of being mocked).
The biggest difference is when changing between chainrings because the compact has a bigger gap.
Riding along in the big ring coming up to a hill, you want to change to the little chainring to get ready for the hill but you dont want to change gear ratios.
So on a double you drop to the little ring and simultaneously click down 2 sprockets on the cassette.
On a compact you need to click down 3 sprockets to keep the same ratio.
There's also a few more options around the middle of the gears which i find more useful than a bigger top end or smaller bottom end.
I have a standard 53-39 chainring with 11-25 cassette. I rarely ever spin out the 53-11 and i only need the 39-25 for the biggest hills, so it suits me fine.
). It started to do this just a few weeks after i got it.The XM-L T6 comes with a battery pack, so it is 'cheap Chinese' battery. Lets hope it's good, I just want to be able to see and be seen when I go out on weekends.
