After watching the iP5S/C keynote Samsung's S5 will not have to try so hard.......
I knew you'd pop up with something like that.
Hey guys, my girlfriend really wants the pink S4... I've found some on eBay but obviously it's coming from Taiwan... Will this be ok for the UK? Just checking before splashing out, thanks in advance.
It's a good place to start, it's deodexed so all the themes and mods will work and all the crap's been removed. No need to flash the modem if yours works, check the wifi is working that can be an issue after a mix of baseband and build.
Get it on and working, do a nandroid backup for a place to go back to. Other than that, see what mods and themes you like. Then look at the various builds that include what you like, plain vanilla or ones with loads of options. Cyanogenmod, GoogleEdition , MIUI, Pacman. There's a lot to play with.
??Better to purchase it from here mate, muon gave a link to one. It's just hassle buying from overseas because if anything goes wrong with it and it needs a warranty repair, Samsung Europe won't do it, you'd have to send it back to Taiwan.
Just seen somebody comment in the Apple section mentioning the S4 runs dog slow?
My S1 was rooted just so I could get it to 4.2 but feel the S4 does not need to be? You loose a lot of the Samsung software, most call it bloat but to me is very useful, multiview, smart features and s planner. To me when you root you are left with a basic device and you have to build it up to how you want it. For me the stock rom is perfect. I cant see how it could be quicker? Every task I do on the phone is opened in the blink of an eye. The only issue I have is the camera in low light conditions and I doubt custom roms can fix this?
The phone is by far the best I have used, I could list the ones I have had and played with but it would be like a novel! I cant quite see how this is possible hence the fact I have not rooted, yet!
Scroll through your contacts list - if it isn't ultra smooth on the GS4 then it just show how poorly it's been designed. For example, the Google Play store is a choppy mess for scrolling. Poorly designed 1st party
What features did you gain going to pacman?
