- 29 Jul 2013
SO jealous, those pink ones are to die for
Went a bit mental in NYC...
Also, for some amusement...my weight going out...
and coming back...
Smells gooooood.
Unfortunately due to work, I probably won't be able to play with it until next week.![]()
That's amazing. Now how to buy it without arousing suspicion from the other half.
Also, for some amusement...suitcase weight going out...
and coming back...
You did change all the stock fans didn't you and how noisy is it?
^^^ That is some beast, what is it for ?!
yes sir, all replaced with corsair AF and SP fans
Noise levels no worse than my old Antec 1200, good to have controller on the case i found.
[/QUOTE]
I'm just about to take the plunge and get one for my new build!
Ohh nice, did you get the rampage board you were after.
I bought a few of these as well as plenty of other screws from another online shop as i wasn't sure what screws came with the case since i went other the top on fans.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-053-AK&groupid=701&catid=1428&subcat=1433
Do them chiclet keys feel fairly solid not too wobbly or mushy?
Is that for me Raymondif it is, i wanted this case so bad should last me a while
haha, ay - it's best as a car freshener!That's amazing. Now how to buy it without arousing suspicion from the other half.
