ASUSTOR - The Whole New range at OcUK!!
20 Jul 2009
Midlands
Hello
OcUK have recently had meetings with ASUSTOR (An ASUS group company) regarding their NAS drives. So what makes these drives so special and appealing to OcUK over QNAP or Synology? Well, neally all of them feature HDMI 1.4 out of the box allowing the use of the product to connect diectly to a TV and then use the XBMC built in to play your music and films! There really is no need for a HTPC with the awesome features on offer from ASUSTOR!!
ASUSTOR AS-202T 2 Bay Network Attached Storage Enclosure @ £179.99 inc VAT
ASUSTOR's ADM operating system combined with an Intel processor allows the 2 series to raise read and write performance to the max.
The 2 series also provides a total of 4 USB ports (2 x USB 3.0, 2 x USB 2.0) allowing you to simultaneously connect up to 4 external USB hard drives to expand your storage capacity.
Furthermore, AS-2TE series comes equipped with an HDMI port and audio jack allowing your NAS to transform into a multimedia player!
Hardware Specifications
- CPU: Intel® ATOM™ 1.2GHz Dual-Core Processor
- Memory: 512MB DDR3
- HDD: 2.5" / 3.5" SATA II/ III or SSD x 2¹ Compatibility
- Expansion: USB 3.0 x 2, USB 2.0 x 2
- Network: Gigabit Ethernet x 1
- Output: N/A
- System Fan: 70mm x 1
- Input Power Voltage: 100V to 240V AC*
- Certification: FCC, CE, VCCI, BSMI, C-TICK
* Recommend WD Red 3 TB HDD
Only £179.99 inc VAT.
ORDER NOW
ASUSTOR AS-204T 4 Bay Network Attached Storage Enclosure @ £299.99 inc VAT
- HDD: 2.5" / 3.5" SATA II/ III or SSD x 4¹ Compatibility
- Output: N/A
Only £299.99 inc VAT.
ORDER NOW
ASUSTOR AS-202TE 2 Bay Network Attached Storage Enclosure @ £199.99 inc VAT
- HD Display: HDMI 1.4 x 1
- Receiver: Infrared
- Audio: 3.5mm Audio Jack, HDMI
- Output: N/A
Only £199.99 inc VAT.
ORDER NOW
ASUSTOR AS-204TE 4 Bay Network Attached Storage Enclosure @ £337.99 inc VAT
- Output: N/A
Only £337.99 inc VAT.
ORDER NOW
ASUSTOR AS-302T 2 Bay Network Attached Storage Enclosure @ £257.99 inc VAT
Able to accommodate up to two hard drives, the AS-302T NAS from Asustor is an easy to use and high performing storage system. With a Gigabit Ethernet connection, the AS-302T is a lasting and stable solution for saving your most important files. With the AS-302T you can connect up to 4 surveillance cameras. You can also easily connect your NAS to your TV through the built in HDMI connectivity and control everything with your smartphone. Very convenient for looking at family photos or videos on your TV.
- CPU: Intel® ATOM™ 1.6GHz Dual-Core Processor
- Memory: 1GB Memory DDR3
- Output: HDMI x 1
- Infrared Receiver
- 3.5mm Audio Jack
Only £257.99 inc VAT.
ORDER NOW
ASUSTOR AS-304T 4 Bay Network Attached Storage Enclosure @ £389.99 inc VAT
Able to accommodate up to four hard drives, the AS-304T NAS from Asustor is an easy to use and high performing storage system. With a Gigabit Ethernet connection, the AS-304T is a lasting and stable solution for saving your most important files. With the AS-304T you can connect up to 4 surveillance cameras. You can also easily connect your NAS to your TV through the built in HDMI connectivity and control everything with your smartphone. Very convenient for looking at family photos or videos on your TV.
- Output: HDMI x 1
- Infrared Receiver
- 3.5mm Audio Jack
Only £389.99 inc VAT.
ORDER NOW
ASUSTOR AS-602T 2 Bay Network Attached Storage Enclosure @ £337.99 inc VAT
Able to accommodate up to two hard drives, the AS-602T NAS from Asustor is an easy to use and high performing storage system. With a Gigabit Ethernet connection, the AS-602T is a lasting and stable solution for saving your most important files. With the AS-602T you can connect up to 4 surveillance cameras. You can also easily connect your NAS to your TV through the built in HDMI connectivity and control everything with your smartphone. Very convenient for looking at family photos or videos on your TV.
- CPU: Intel® Atom™ 2.13 GHz Dual-Core Processor
- Memory: 1GB SO-DIMM DDR3 (Expandable. Max. 3GB)
- HDD: 2.5" or 3.5" SATA II/ III x 2¹
- Expansion: USB 3.0 x 2, USB 2.0 x 4, eSATA x 2
- Network: Gigabit Ethernet x 2
- Output: HDMI x 1
ORDER NOW
ASUSTOR AS-604T 4 Bay Network Attached Storage Enclosure @ £449.99 inc VAT
Able to accommodate up to four hard drives, the AS-604T NAS from Asustor is an easy to use and high performing storage system. With a Gigabit Ethernet connection, the AS-604T is a lasting and stable solution for saving your most important files. With the AS-604T you can connect up to 4 surveillance cameras. You can also easily connect your NAS to your TV through the built in HDMI connectivity and control everything with your smartphone. Very convenient for looking at family photos or videos on your TV.
- HDD: 2.5" or 3.5" SATA II/ III x 4¹
- Output: HDMI x 1
Only £449.99 inc VAT.
ORDER NOW
ASUSTOR AS-606T 6 Bay Network Attached Storage Enclosure @ £569.99 inc VAT
Able to accommodate up to six hard drives, the AS-606T NAS from Asustor is an easy to use and high performing storage system. With a Gigabit Ethernet connection, the AS-606T is a lasting and stable solution for saving your most important files. With the AS-606T you can connect up to 4 surveillance cameras. You can also easily connect your NAS to your TV through the built in HDMI connectivity and control everything with your smartphone. Very convenient for looking at family photos or videos on your TV.
- HDD: 2.5" or 3.5" SATA II/ III x 6¹
- Output: HDMI x 1
Only £569.99 inc VAT.
ORDER NOW
ASUSTOR AS-608T 8 Bay Network Attached Storage Enclosure @ £667.99 inc VAT
Able to accommodate up to eight hard drives, the AS-608T NAS from Asustor is an easy to use and high performing storage system. With a Gigabit Ethernet connection, the AS-608T is a lasting and stable solution for saving your most important files. With the AS-608T you can connect up to 4 surveillance cameras. You can also easily connect your NAS to your TV through the built in HDMI connectivity and control everything with your smartphone. Very convenient for looking at family photos or videos on your TV.
- HDD: 2.5" or 3.5" SATA II/ III x 8¹
- Output: HDMI x 1
Only £667.99 inc VAT.
ORDER NOW
ASUSTOR AS-604RS 4 Bay Network Attached Storage Enclosure @ £659.99 inc VAT
The AS-604RS / AS-604RD provides businesses with a cost-effective, full-featured network storage solution. It safeguards your most precious data while allowing you to take advantage of a wealth of add-on applications to increase productivity.
- Memory: 1GB SO-DIMM DDR3 (Expandable. Max. 3GB) Installation Guide
- HDD: 2.5" or 3.5" SATA II/ III x 4¹ Compatibility
- Output: HDMI x 1
- System Fan: 40mm x 1
Only £659.99 inc VAT.
ORDER NOW
ASUSTOR AS-604RD 4 Bay Network Attached Storage Enclosure @ £947.99 inc VAT
- Output: HDMI x 1
- Redundant Power Supply
Only £947.99 inc VAT.
ORDER NOW
ASUSTOR AS-609RS 9 Bay Network Attached Storage Enclosure @ £1,129.99 inc VAT
The AS-609RS / AS-609RD is equipped with dual gigabit Ethernet ports and 9 drive bays, providing a stable environment for data exchange and storage while providing data protection and sustainable management.
- HDD: 2.5" or 3.5" SATA II/ III x 9¹ Compatibility
- Output: HDMI x 1
- System Fan: 60mm X2
Only £1,129.99 inc VAT.
ORDER NOW
ASUSTOR AS-609RD 9 Bay Network Attached Storage Enclosure @ £1,399.99 inc VAT
- Output: HDMI x 1
Only £1,399.99 inc VAT.
ORDER NOW
ASUSTOR Remote Control for AS-3 and AS-2xxTE series for XBMC @ £23.99 inc VAT
The ASUSTOR Remote Control adds the function to control your AS-3 and AS-2xxTE series of NAS for XBMC and other programs compatible with the infrared remote.
With ASUSTOR AS-3 and AS-2xxTE series NAS there really is no need for a HTPC!
- Remote Control
Only £23.99 inc VAT.
ORDER NOW
NAS never interested me before and then I had a play with one of these and I really want one now. :)
You can also control them with an APP on your mobile device too from anywhere. :)
Do these support full support for all encoding formats? I would guess so but would like 100% clarification.
May ditch my HTPC for one of these, if so.
They allow for 4TB drives yes, we just recommenced the 3TB red as its the best value for money :)
Yes, they also have an app store to download apps just like synology.
Illcheck the file formats for you Ace, I shall be getting one of these for sure now as itll mean no need for a HTPC and any other expense involved.
Worst case you download in one format and convert for the xbmc but I have been led to believe that what ever xbmc supports these do too :)
As for the advantage over a dedicated server, I guess that depends on the requirements and the speed needed. If the spec can cope with what you need it for then a server will become void of use if you have these also :)
Some of them support security cameras but no mention of the type of connection or cameras?
This is something that we will add to the descriptions once we have more details. For the time being the only info available is on asustor web page and thats not exactly helpful in some cases at present.
What sort of advantage do the larger more expensive NAS offer over a dedicated file server computer set up in a rack server case?
  • Ease of use
  • Cheaper than Fileserver
  • 'Desktop' rather than rackmount/server space
  • No/very little software licencing costs
  • Cheaper to replace
  • Cheaper to run (power use)
But bear in mind, a Fileserver will be much more powerful, can host databases, network integration, increased security, better upgrade options, backups/synchronising data etc!
Anyone know how well they can run Sabnzbd, if they even can?
Most of the time, NAS boxes can't run past 3MB/s due to the CPU not being beefy enough.
Nice but way over priced the same as the synology Nas.
Oh Gibbo who:D:D who did :D:D:D who did them avatars :D:D:D:D:D
The 2 series are cheaper and offer more...
The 3 series offer more than the equivelent spec QNAP and Synology too. I dont see how they are way over priced or even over priced? Like for like they are cheaper.
They are, it seems mental.
I agreed until I played with a proper big boys NAS in work. It was a Synology 10 drive rack unit using 10Gb LAn and the thing is amazing! Can manage sustained 700 megabytes/s, but it was the OS and way it worked that impressed me most.
What would make sense for home use (the OS and general setup is the same between the domestic and SME):
As it uses a linux based OS for the RAID rather than RAID driven by a RAID card, it can actually spin down all the drives when not in use, so they are pretty power frugal. The apps and things included/ downloadable pretty much cover 99% of things you're likely to do with a home server, and its a set it and forget it (torrent/ media server/ ftp server/ mail server/ DHCP server etc). All without the need to be a Linux guru to get it all working. My home server is linux based and some of the things I run took me ages to work out......
I have considered buying one for home but I already have a home server I've built up over years with a 3Ware raid card and 12 1Tb SATA drives. Can't really justify throwing that all away and starting again.
E-I
