- 20 Jul 2009
- The bleak North East arm pit of Britain
Hello
OcUK have recently had meetings with ASUSTOR (An ASUS group company) regarding their NAS drives. So what makes these drives so special and appealing to OcUK over QNAP or Synology? Well, neally all of them feature HDMI 1.4 out of the box allowing the use of the product to connect diectly to a TV and then use the XBMC built in to play your music and films! There really is no need for a HTPC with the awesome features on offer from ASUSTOR!!
ASUSTOR AS-202T 2 Bay Network Attached Storage Enclosure @ £179.99 inc VAT
ASUSTOR's ADM operating system combined with an Intel processor allows the 2 series to raise read and write performance to the max.
The 2 series also provides a total of 4 USB ports (2 x USB 3.0, 2 x USB 2.0) allowing you to simultaneously connect up to 4 external USB hard drives to expand your storage capacity.
Furthermore, AS-2TE series comes equipped with an HDMI port and audio jack allowing your NAS to transform into a multimedia player!
Hardware Specifications
- CPU: Intel® ATOM™ 1.2GHz Dual-Core Processor
- Memory: 512MB DDR3
- HDD: 2.5" / 3.5" SATA II/ III or SSD x 2¹ Compatibility
- Expansion: USB 3.0 x 2, USB 2.0 x 2
- Network: Gigabit Ethernet x 1
- Output: N/A
- System Fan: 70mm x 1
- Input Power Voltage: 100V to 240V AC*
- Certification: FCC, CE, VCCI, BSMI, C-TICK
* Recommend WD Red 3 TB HDD
Only £179.99 inc VAT.
ORDER NOW
ASUSTOR AS-204T 4 Bay Network Attached Storage Enclosure @ £299.99 inc VAT
- HDD: 2.5" / 3.5" SATA II/ III or SSD x 4¹ Compatibility
- Output: N/A
Only £299.99 inc VAT.
ORDER NOW
ASUSTOR AS-202TE 2 Bay Network Attached Storage Enclosure @ £199.99 inc VAT
- HD Display: HDMI 1.4 x 1
- Receiver: Infrared
- Audio: 3.5mm Audio Jack, HDMI
- Output: N/A
Only £199.99 inc VAT.
ORDER NOW
ASUSTOR AS-204TE 4 Bay Network Attached Storage Enclosure @ £337.99 inc VAT
- Output: N/A
Only £337.99 inc VAT.
ORDER NOW
ASUSTOR AS-302T 2 Bay Network Attached Storage Enclosure @ £257.99 inc VAT
Able to accommodate up to two hard drives, the AS-302T NAS from Asustor is an easy to use and high performing storage system. With a Gigabit Ethernet connection, the AS-302T is a lasting and stable solution for saving your most important files. With the AS-302T you can connect up to 4 surveillance cameras. You can also easily connect your NAS to your TV through the built in HDMI connectivity and control everything with your smartphone. Very convenient for looking at family photos or videos on your TV.
- CPU: Intel® ATOM™ 1.6GHz Dual-Core Processor
- Memory: 1GB Memory DDR3
- Output: HDMI x 1
- Infrared Receiver
- 3.5mm Audio Jack
Only £257.99 inc VAT.
ORDER NOW
ASUSTOR AS-304T 4 Bay Network Attached Storage Enclosure @ £389.99 inc VAT
Able to accommodate up to four hard drives, the AS-304T NAS from Asustor is an easy to use and high performing storage system. With a Gigabit Ethernet connection, the AS-304T is a lasting and stable solution for saving your most important files. With the AS-304T you can connect up to 4 surveillance cameras. You can also easily connect your NAS to your TV through the built in HDMI connectivity and control everything with your smartphone. Very convenient for looking at family photos or videos on your TV.
- Output: HDMI x 1
- Infrared Receiver
- 3.5mm Audio Jack
Only £389.99 inc VAT.
ORDER NOW
ASUSTOR AS-602T 2 Bay Network Attached Storage Enclosure @ £337.99 inc VAT
Able to accommodate up to two hard drives, the AS-602T NAS from Asustor is an easy to use and high performing storage system. With a Gigabit Ethernet connection, the AS-602T is a lasting and stable solution for saving your most important files. With the AS-602T you can connect up to 4 surveillance cameras. You can also easily connect your NAS to your TV through the built in HDMI connectivity and control everything with your smartphone. Very convenient for looking at family photos or videos on your TV.
- CPU: Intel® Atom™ 2.13 GHz Dual-Core Processor
- Memory: 1GB SO-DIMM DDR3 (Expandable. Max. 3GB)
- HDD: 2.5" or 3.5" SATA II/ III x 2¹
- Expansion: USB 3.0 x 2, USB 2.0 x 4, eSATA x 2
- Network: Gigabit Ethernet x 2
- Output: HDMI x 1
ORDER NOW
ASUSTOR AS-604T 4 Bay Network Attached Storage Enclosure @ £449.99 inc VAT
Able to accommodate up to four hard drives, the AS-604T NAS from Asustor is an easy to use and high performing storage system. With a Gigabit Ethernet connection, the AS-604T is a lasting and stable solution for saving your most important files. With the AS-604T you can connect up to 4 surveillance cameras. You can also easily connect your NAS to your TV through the built in HDMI connectivity and control everything with your smartphone. Very convenient for looking at family photos or videos on your TV.
- HDD: 2.5" or 3.5" SATA II/ III x 4¹
- Output: HDMI x 1
Only £449.99 inc VAT.
ORDER NOW
ASUSTOR AS-606T 6 Bay Network Attached Storage Enclosure @ £569.99 inc VAT
Able to accommodate up to six hard drives, the AS-606T NAS from Asustor is an easy to use and high performing storage system. With a Gigabit Ethernet connection, the AS-606T is a lasting and stable solution for saving your most important files. With the AS-606T you can connect up to 4 surveillance cameras. You can also easily connect your NAS to your TV through the built in HDMI connectivity and control everything with your smartphone. Very convenient for looking at family photos or videos on your TV.
- HDD: 2.5" or 3.5" SATA II/ III x 6¹
- Output: HDMI x 1
Only £569.99 inc VAT.
ORDER NOW
ASUSTOR AS-608T 8 Bay Network Attached Storage Enclosure @ £667.99 inc VAT
Able to accommodate up to eight hard drives, the AS-608T NAS from Asustor is an easy to use and high performing storage system. With a Gigabit Ethernet connection, the AS-608T is a lasting and stable solution for saving your most important files. With the AS-608T you can connect up to 4 surveillance cameras. You can also easily connect your NAS to your TV through the built in HDMI connectivity and control everything with your smartphone. Very convenient for looking at family photos or videos on your TV.
- HDD: 2.5" or 3.5" SATA II/ III x 8¹
- Output: HDMI x 1
Only £667.99 inc VAT.
ORDER NOW
ASUSTOR AS-604RS 4 Bay Network Attached Storage Enclosure @ £659.99 inc VAT
The AS-604RS / AS-604RD provides businesses with a cost-effective, full-featured network storage solution. It safeguards your most precious data while allowing you to take advantage of a wealth of add-on applications to increase productivity.
- Memory: 1GB SO-DIMM DDR3 (Expandable. Max. 3GB) Installation Guide
- HDD: 2.5" or 3.5" SATA II/ III x 4¹ Compatibility
- Output: HDMI x 1
- System Fan: 40mm x 1
Only £659.99 inc VAT.
ORDER NOW
ASUSTOR AS-604RD 4 Bay Network Attached Storage Enclosure @ £947.99 inc VAT
- Output: HDMI x 1
- Redundant Power Supply
Only £947.99 inc VAT.
ORDER NOW
ASUSTOR AS-609RS 9 Bay Network Attached Storage Enclosure @ £1,129.99 inc VAT
The AS-609RS / AS-609RD is equipped with dual gigabit Ethernet ports and 9 drive bays, providing a stable environment for data exchange and storage while providing data protection and sustainable management.
- HDD: 2.5" or 3.5" SATA II/ III x 9¹ Compatibility
- Output: HDMI x 1
- System Fan: 60mm X2
Only £1,129.99 inc VAT.
ORDER NOW
ASUSTOR AS-609RD 9 Bay Network Attached Storage Enclosure @ £1,399.99 inc VAT
- Output: HDMI x 1
Only £1,399.99 inc VAT.
ORDER NOW
ASUSTOR Remote Control for AS-3 and AS-2xxTE series for XBMC @ £23.99 inc VAT
The ASUSTOR Remote Control adds the function to control your AS-3 and AS-2xxTE series of NAS for XBMC and other programs compatible with the infrared remote.
With ASUSTOR AS-3 and AS-2xxTE series NAS there really is no need for a HTPC!
- Remote Control
Only £23.99 inc VAT.
ORDER NOW
- Output: N/A
ORDER NOW
- Output: N/A
ORDER NOW
- Output: N/A
ORDER NOW
- Output: N/A
ORDER NOW
- Output: HDMI x 1
- Infrared Receiver
- 3.5mm Audio Jack
ORDER NOW
- Output: HDMI x 1
- Infrared Receiver
- 3.5mm Audio Jack
ORDER NOW
- Output: HDMI x 1
ORDER NOW
- Output: HDMI x 1
ORDER NOW
- Output: HDMI x 1
ORDER NOW
- Output: HDMI x 1
ORDER NOW
- Output: HDMI x 1
ORDER NOW
- Output: HDMI x 1
ORDER NOW
- Output: HDMI x 1
ORDER NOW
- Output: HDMI x 1
ORDER NOW
- Remote Control
ORDER NOW
