Parvum Systems Project Magnus
6 Mar 2013
Parvum Systems Project Magnus - 20th Sep - Case assembled
Project:
Magnus
by: Parvum Systems
Sponsors/Support:
Hello ladies and gentleman. It's that time!
We are back! A very exciting time indeed! We have been working hard in the warehouse trying to get on top of stock and orders for Parvum cases! However in our evenings and our own spare time we have done our very best to work on a new project.
A quick word about the sponsors. As with all of these builds they are not the most traditional where you simply do a build and get sponsor stuff in exchange for finishing the build. All parts that we have been lucky to get for this build are 90% trade items. So to say... you scratch my back I'll scratch yours. We have done custom case work for pretty much all of the companies who have supported this project and intend to do much more.
This project will be the first ever full size Parvum Systems case. It will feature a full size ATX board and multiple GPUs. Please understand the purpose of this is to also act as a working prototype.
This won't be the end user 'retail' tower but a lot of the techniques we use and features seen here will be in the final product. Also understand any feedback, criticism & ideas received here will be taken on board. The whole point is to make our cases as perfect as we can!
A little break down of what we already know for the build; Understand it is overkill. This is the one time we are going to go crazy... all the hardware, all the watercooling.. a really powerful build:
  • 5 X 240mm Radiators
  • 1 x 360mm Radiators
  • 18 x 120mm Fans
  • 1 x Haswell CPU
  • 1 X 4 Way SLI Motherboard
  • 4 X GPUs
  • 3 X D5 Pumps
  • 8 X SSD
  • 3 X 3TB Storage drives
  • 1 X SATA 3 Raid card
Our personal building style doesn't really favor much from rendering, if we do use them its more to ensure we've not screwed up with a length of a panel or a screw hole here or there. So I do have a render but this is a lose idea of the build. Something for you to see to give you an idea.
We never sketchup the hardware or the loop. These things come to us when the builds actually in front of us.
The one thing that is a certainty is the almost 500mm of clear acrylic tubing that will be mounted into the front panel system of the case. Should be a nice little feature!
Here are a couple of quick renders to give you an idea of the over all look/feel:
To give you an idea of our previous work. See two photos; Project ITX & Onwards and upwards. mATX for the bigger case, ITX for the smaller. This should give you a good idea of our overall build style and give you an idea of what to expect but on a much larger scale:
Over the last couple of months we have been tweaking the design. Finally we are happy to a stage where some can be cut:
So before I show you the initial panels... we have been very lucky here at Parvum Systems. I suppose a combination of dedication & support from all you guys has led to this! On the 17th of this month we had an extremely awesome CNC system installed. We had a couple of days training as standard with the machine and got on really well with the technician. Was a great couple of days and we pretty much got straight to optimizing Parvum case cutting. Even made a new friend ;)!
Here are a couple of shots of the installation and cutting of the first panels for this case:
So to show you a little bit of the cutting for today. The first BIG mid wall! Was fun to bend it, had to make a slightly bigger jig. Pretty standard here just more standoffs and more size!
We changed the 24pin & 8pin EPS to small drilled holes for neater cable management. We also changed the hole placement for things like Sata cables to be 50% under the motherboard. Again to keep it all nice and tidy. We actually used a photo template of the board to ensure everything is in the exact place before the we physically had the motherboard:
http://cartel.parvumsystems.com/pl/magnus/25.jpg[/IMG
[IMG]http://cartel.parvumsystems.com/pl/magnus/26.jpg
Basically just wanted to just get this project log up and online. We have actually cut 75% of the panels so we will assemble after work tonight or tomorrow and get the initial assembly photos online in the next update! We will start to filter in some of the parts & hardware provided by our sponsors and show you some more of the plans ASAP.
Thanks again everyone. Hope this one will be a great project for us to enjoy together! As always if you have any questions... want to know a little more about something or what something is just ask.
Justin, Shaun..
Parvum Systems!
Wow.
I was going to mail you chaps about an atx case the other night but thought better of it.
Build sounds extra epic.
Any idea when the atx cases will be put on sale? Very much peaked my interest, especially if I can have a custom one to hold a couple of 480's :D
new machine looks epic. cant wait to buy more cases off you guys :D
the design for the ATX case is brilliant. really looking forward to seeing this come together.
After seeing your tweets of that CNC installed I couldn't wait to see what you guys had planned. Glad to see I'm not going to be disappointed. :D
Cannot wait to see the finished case/project! Good luck with this one.
Wow.
Well we may be one step ahead in that case! It's hard to say, we aim to fore fill our purchase orders for the S1.0 initially. We then plan to get the ITX on sale next month. With the new machine however everything should start to move along much faster! A case to fit a couple of 480's could be lovely :D
That case design looks incredible, looking forward to watching this build develop
New Parvum build - Subbed guys
Thank you all! Will have some photos of the builds initial assembly today :D
Thanks for following mate. Yeah the CNC is a dream. Such a crazy piece of kit.
I may just hold out on buying the enthoo in that case then :D
That is one very large bit of kit, bet that made your day when it arrived.
Loving the inverted atx (but for a SFF company that's one massive ATX case)
Will be interesting to see if the side panels work, without a fixing in the middle.
But love that white 'halo' round the side panel that's unique to your case construction.
And the legs are also a nice improvement over the S1.0 design.
I toyed with that leg design when doing 'project 20', with the IO/cable coming out the base and the passive rad in the roof.
Just went with an easier design as it was my first complete rebuild project.
Must get you guys to send me a rear panel cutout/off cut (in white) for a idea I've had.
Case assembly
Sponsors/Support:
Assembling the first of the panels:
Back once again (for the renegade master)... for another update. Not sure why I posted these lyrics, but it is the weekend now! Almost...
Apologize here for my writing style and for how many exclamation marks I use. I suppose I get a bit carried away some times.
First then we assemble the front part of the case. This is made up of 3 x 5mm thick layers. White first, then frosted followed by black. Really wanted to use the frosted on top of white after our ROG ITX build. Also the primary reason for this was to give us enough thickness to inlay the 12mm acrylic tubing:
Really happy with the new 'squarer' detailing used for the USB 3 header. Also hard to see in the photo but a very slight chamfer to slit for the slot loading drive:
Frosted on white with some of the cubes installed:
Note here the removed section to allow the 90° bent tubing to pass through into top and bottom chambers:
Some more photos of the front assembly, the USB and drive detailing. Then the third front layer:
Installed the case bottom and the internal bottom chamber:
Top chamber & middle wall in place. Lots of white space inside this case:
I will shut up talking and continue assembly now:
Last little update for tonight; wanted to check the USB header fit with no issue. We decided to inlay the full plastic unit into the back of the white. To then be screwed into the clear in the front as usual:
That's your lot then guys and girls!
Hope your enjoying this so far... it's hard to see the case as we see it. This case will very much change when we start to get some hardware and cooling inside. But so far couldn't be happier.
Have a great weekend and please, hit us with some comments and ideas as and when you get them! We like ideas :D
Justin, Shaun,
