- 25 Apr 2010
- Ipswich
hahaa he bought a lot!
My rose should come this week :O or next
D
It's all good even if they're rubbish copies - you'll have plenty of stock for rewicking/coilingDon't throw away your old heads. I actually like the FT replacement EVOD heads better than the Kanger ones. Once you remove the crap coil and wick and add your own, they're perfect.
RedMogg - I tried a bit of cotton wool wick, nearly had a vapegasm. Did it a bit wrong though, got a bit of leaking and flooding going on now. Might have another go later. It's like chasing a heroin rush, only a bit cheaper. Arguably more destructive, productivity wise, though![]()
what atty did you use cotton in? If it is flooding and leaking, you added too much juice or the seals weren't tightened enough. If juice is leaking from the air hole then just follow these tips: 30mins onwards
http://www.youtube.com/watch?v=cKIJFkOddts
Anyone know where I can get a kayfun lite cloud 9 vaping never seem to have any
Cheers pal
Just got the kayfun stock notification. One on the way now. I cant comment the kayfun mine but the lite is amazing my mate has one and its so smooth
Anyone here used or have a kayfun mini? Got one in my shopping basket just not sure about hitting go!
Predators plasma is an interesting flavour.
To the people asking about the Kayfun mini/lite I myself have just purchased the Kayfun lite.
Before you know my opinion it's probably I tell you the following
Equipment I've owned/tried and save the best for last, this points will be brief.
ego 650mha (has a terrible battery life but works okay for a starter)
ce4 clearomiser (flavour is limited as is throat hit but works and can be recoiled easily)
v5 clearomiser (worse than above, can't recoil unless you solder etc)
Innoking SVD (Works well and does the job very well, scratches easily, too large but a reliable mod I'd recommend for home/office use. If using this in front of people be prepared to have people call it a sonic screw driver and stare at you weirdly)
Iclear 30's (reasonable throat hit but you can't really tell whilst inhaling that you're even using it, muted flavour but slightly better than the ce4's, nightmare to recoil like the V5's)
Protank original (harsh hitter especially with high pg mixes, which has it's pros and cons, simply works, is easy to recoil and brings out the flavour more than the above, has an airy draw)
The Kayfun Lite (A different league in build quality compared to the rest, it works well, takes a little while to learn how to coil but once you get it right it works well, this item scrathes easily like the SVD and has an airier draw than the protank. Apparently there is a fix for this though should you not like it but I've now got used to it. overall flavour/throat hit is good and the best I've tried so far, the down side to this item however is that it leaks out the airhole if stored horizontalyl and the air hole isn't facing upwards. For this reason I recommend it for indoors use only unless stored upright in your pocket at all times)
