Hi Guys,
The New Corsair 750D is due at OcUK very soon. This is looking to be a go to choice for watercooling as a lower level 900D.
The radiator capabilities of this case are brilliant and the finish is usual Obsidian quality.
Gallery:
Corsair Obsidian 750D Full Tower Case - Black (CC-9011035-WW) @ £134.99 inc VAT
The Obsidian Series 750D full tower PC case combines generous expansion flexibility, room for advanced cooling options, and fast and easy builds and upgrades. It has a clean, elegant exterior that dispenses with arbitrary plastic add-ons in exchange for the beauty of brushed aluminum and solid steel. This rigid, rugged exterior surrounds a frame that has ample room for high-performance components and the sophisticated cooling you’ll need if you’re going to push those components to their limits. And, it incorporates a host of clever system builder-focused features, because building a system should be straightforward, trouble-free, and even fun.
Features:-
- Generous expansion room for building high-performance systems.
- Beautiful brushed aluminum fascia makes an elegant design statement.
- Full side panel window to view your components.
- Tool-free SSD, Hard Drive, and Optical Drive installation.
- Includes three AF140L fans, with room for up to eight fans.
- Designed for fast and straightforward builds.
Modular drive cage system for highly customizable layouts.
- Two modular drive cages house three 3.5¡¨ or 2.5¡¨ drives each.
- Four tool-free dedicated SSD cages, sideways mounted.
Radiator and fan compatibility compatibility:
- Top: 3 x 120mm or 2 x 140mm
- Front: 2 x 140mm or 2 x 120mm (2 x 140mm included)
- Bottom: 2 x 120mm
- Rear: 1 x 140mm or 120mm (140mm included)
- Two USB 3.0 and two USB 2.0 front panel connectors, plus headphone and microphone.
- Easily accessed front, top, and PSU dust filters.
- Excellent cable routing with rubber grommets for clean builds.
- Nine expansion slots for multiple PCI-E devices or large motherboards
- Maximum CPU Cooler Height 170mm
- Maximum GPU Length 450mm
Only £134.99 inc VAT.
ORDER NOW
Gallery:
Features:-
- Bottom: 2 x 120mm
ORDER NOW
