** Corsair 750D - Available to pre order NOW **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys,
The New Corsair 750D is due at OcUK very soon. This is looking to be a go to choice for watercooling as a lower level 900D.
The radiator capabilities of this case are brilliant and the finish is usual Obsidian quality.
Gallery:
Corsair Obsidian 750D Full Tower Case - Black (CC-9011035-WW) @ £134.99 inc VAT
The Obsidian Series 750D full tower PC case combines generous expansion flexibility, room for advanced cooling options, and fast and easy builds and upgrades. It has a clean, elegant exterior that dispenses with arbitrary plastic add-ons in exchange for the beauty of brushed aluminum and solid steel. This rigid, rugged exterior surrounds a frame that has ample room for high-performance components and the sophisticated cooling you’ll need if you’re going to push those components to their limits. And, it incorporates a host of clever system builder-focused features, because building a system should be straightforward, trouble-free, and even fun.
Features:-
- Generous expansion room for building high-performance systems.
- Beautiful brushed aluminum fascia makes an elegant design statement.
- Full side panel window to view your components.
- Tool-free SSD, Hard Drive, and Optical Drive installation.
- Includes three AF140L fans, with room for up to eight fans.
- Designed for fast and straightforward builds.
Modular drive cage system for highly customizable layouts.
- Two modular drive cages house three 3.5¡¨ or 2.5¡¨ drives each.
- Four tool-free dedicated SSD cages, sideways mounted.
Radiator and fan compatibility compatibility:
- Top: 3 x 120mm or 2 x 140mm
- Front: 2 x 140mm or 2 x 120mm (2 x 140mm included)
- Bottom: 2 x 120mm
- Rear: 1 x 140mm or 120mm (140mm included)
- Two USB 3.0 and two USB 2.0 front panel connectors, plus headphone and microphone.
- Easily accessed front, top, and PSU dust filters.
- Excellent cable routing with rubber grommets for clean builds.
- Nine expansion slots for multiple PCI-E devices or large motherboards
- Maximum CPU Cooler Height 170mm
- Maximum GPU Length 450mm
Only £134.99 inc VAT.
ORDER NOW
Its a lot of case for the money. The product pics we have are unique and really show off the full capability of this chassis.
I would say this was more a 650D replacement... right price range, same number of hard drive bays and optical bays, just better designed (slightly cheaper in fact)
Wow. I'm genuinely surprised by the price given the 900D price. Thought this'd be coming in at around £200. Looks like rather than bridging the gap between the 650D and 900D they've replaced the former.
