Rads and fans
Sponsors/Support:
This time will actually be a mini update
 haha. Mainly to show you a few bits from the sponsors/support and what not.
First up is the fans. Phobya have supplied the build with 17 of these little gems. Really liked them when I was first shown them and now the black version comes out.. it was meant to be!
Thanks Pascal.
Time to start making custom length cables. The current plan is for most of the rear and cable management to be visible so it was a must. Plus due to size alone most of the cables wouldn't have even been long enough:
And the part I hate the most. Solder time....
With his new length cable and some Shade 19 MDPC braid:
Next up some of the goodies from XSPC; super stoked on these fittings. We used them first in the ITX build. Love the shape and overall size. Feel nice and chunky and very suitable for this build. Black chrome finish on these:
We move onto the radiators of choice. Decided to use the white rads as the fans are black and will break up the colour enough between the fans and the inside of the case.
These are currently my favorite radiator and aesthetically nothing touches them for me. Really want to use the smaller 120mm versions in an ITX project!
A big thanks goes out to Paul for helping set this up. Really enjoying the current XSPC range. They seem to be really on point with their latest and coming range of products.
To finish for the day.. as I said it is a short update we simply had a little test look at two of the rads inside Magnus:
Until next time
