** FREE SHIPPING FOR YOUR ENTIRE ORDER FOR ALL: SELECTED AMD CARDS PLUS A NEW WEBSITE FEATURE!! **
OcUK Staff
OP
17 Oct 2002
OcUK HQ
If the new cards are just rebadged will their overclock-ability be very similar to 79xxs anyone guess?
Yes, same cards. :)
HIS are simply re-flashing the BIOS on current cards, so its a simple BIOS re-flash and new packaging. Exactly same as what NVIDIA did with GTX 680 re-worked/re-flashed to GTX 770. Whether or not the clock speeds will be upped or lowered is unknown. But essentially the same card/hardware, so same overclock possible.
6 Feb 2010
Yes, same cards. :)
Any idea if the AMD's new "TrueAudio" feature will be supported by current Tahiti based card, or is it something that would only be available to Hawaii based card (and/or possibly the new Tahiti cards- R270 R280 etc)?
18 Aug 2013
Yes, same cards. :)
cheers mate
18 Jun 2013
Cracking prices and that's a brilliant new feature to the website, clearly showing what you get free with certain products. Top job guys :D
