- 22 Aug 2011
- Ireland
Hi there
Those who had the issue, please check our site now, should be fixed, one of our servers had haulted.
Works here now
Hi there
Working ok now!, bet that caused a bit of sweating!![]()
If the new cards are just rebadged will their overclock-ability be very similar to 79xxs anyone guess?
Any idea if the AMD's new "TrueAudio" feature will be supported by current Tahiti based card, or is it something that would only be available to Hawaii based card (and/or possibly the new Tahiti cards- R270 R280 etc)?Yes, same cards.
HIS are simply re-flashing the BIOS on current cards, so its a simple BIOS re-flash and new packaging. Exactly same as what NVIDIA did with GTX 680 re-worked/re-flashed to GTX 770. Whether or not the clock speeds will be upped or lowered is unknown. But essentially the same card/hardware, so same overclock possible.
cheers mateYes, same cards.
but price wise its similar to GTX 780 but slightly faster, right now, of course AMD could change the launch price at any time.![]()
