NOT SURE IF SERIOUSthat glorious 5 cylinder sound
Anyone have experience of BMW covering repair work/parts through goodwill?
My 2008/57 Z4 3.0si (FBMWSH, 43k miles, no warranty) brought up the DSC, ABS and general warning lights all at once last week, I was away over the weekend but they were still on when I got back so got it into the dealers (Eastern BMW, just outside Edinburgh). Anyway, the DSC unit has failed (£2200 for part and labour) and the camshaft wear sensor is showing an issue so they need to take the head off to investigate further (£1250 just for the diagnosis) - a lot of money for a car worth <£10k.
The dealers are submitting a goodwill claim to BMW for the DSC unit but said that diagnosis work isn't covered which seems off, I phoned BMW UK customer service and they said a claim could be submitted after the work had been done, however. It's waiting on a response from BMW about the DSC unit and my approval on investigating the camshaft wear issue.
Hopefully it seems like a strong case for goodwill, I don't think major parts like these should be failing with this age/mileage/service history - it's only money, but money I'd rather spend on something else.
Guys, M135i. How easy is the golf tee mod and does it make a fair difference to the engine noise? Can't help but think it's a little muted and that glorious 5 cylinder sound needs to be heard properly.
The sound in the cabin is generated via the car stereo, it sounds pretty good along with the pops from the exhaust as the auto box changes up a gear. Not sure if it even has the flaps in the exhaust as it is pretty loud on start up in the morning.
[TW]Fox;25010805 said:Who did you buy it from?
I thought it was only the new M5 that did that and not the M135i for example?
Another thing that bothered me, my left leg was right next to the transmission tunnel the whole time, just seemed a little tight towards the pedals on the left side. Not sure I could get used to that.
Did the one you drove have the adaptive suspension or M Sport options? BMW gave me the car over night and it had the standard stuff on, I didn't find it too bad but I wasn't caning it through the bends too much.
Standard suspension, it's a friend's so I have driven it quite a lot. It doesn't like quick changes of direction I suspect adaptive suspension would sort this out. The deals you can get on them are too good not to buy over an A45 AMG but I do think the A45 is the better car.
A wee independent dealer in early 2012, I'm the second owner.
Exactly how I felt Chris.Sometimes I feel that the actual experience of driving a car means more than outright pace and when you're talking about 320bhp + there becomes a finite amount of power that becomes usable on the road without it being simply too fast.
[TW]Fox;25011056 said:This is going to reduce your chance of goodwill - they are going to look at it and think 'You didn't even buy it from us but you want us to pay to fix it?'. Have you had it serviced at BMW? That'll help.
Anyone having an N54 engined car? Does it have a rattle when you rev it and the revs drop?
