- 31 May 2004
- The 'Toon, UK, in Europe
So those that are using it, Clean install? Or just upgrade over current OS?
Did both:
- upgrade on the MBA over DP8
- clean on the iMac (previously Mountain Lion)
Used both over the weekend quite a bit and to be honest, they're both pretty much the same. Did try an upgrade on the iMac at first, but there was an oddity on Displays preferences where the depitction of the display was upside down!... thought I'd do a clean later on instead, no Aussie monitor this time.
I've got a Mac Pro in for upgrade that I'll need to do this week, but I'm not anticipating any shenanigans with that one.
As per the later issues of the DP, all my core apps just work and I've not had to upgrade anything to newer (read "paid") versions to get them working.
