- 17 Mar 2011
- Snowdonia
If you want to play it safe try 1.100mv-1.150mv.
Thanks.
So far I've raised the core clock from default 900 to 1030Mhz and voltage from 1031 to 1063mV and I'm seeing a 5 fps increase in average and minimum fps on Unigine Valley Extreme preset, temps not exceeded 60c so I guess I'm on the right track. I hear 13.11v1 runs cooler too so might try those later.
One annoyance is if I get a freeze when testing, games run slower afterwards unless I reboot (even when clocks reset to default).
