I don't know, you used winflash and not atiflash. You should have followed my bios flashing guide here.
Follow that guide and try using this bios if you have a HIS 7950 Ice-Q. If http://www.sendspace.com/file/5mv49f
If you have a different card maybe stick with the bios you've already got.
Try aiming for 1100/1250 using 1.2v vcore. If thats stable then try 1100/1400. If thats ok then move up to 1100/1500. Once you've got that fully game stable for several hours then worry about pushing the core further.
Oh ok, I'll try your flashing guide when I get home tonight. Do I need to flash back to the stock BIOS before doing so or is it ok to go ahead with the one I've got? I do have a HIS 7950 Ice-Q, so I'll use that BIOS you posted.
After that I'll go with your advice about memory speed. Thanks
