Well for the sake of a few cm, as the Phenom/ Prodigy isn't that much smaller than the Asgard Pro, I would get this.
It is 11.5CM taller and 10CM deeper, thats 25% bigger.
The Phenom is wider though.
I tried, but you might want to detach yourself from the case as its a little difficult to get a decent PC into that case with your budget, partly because the case itself is £85, and partly because it can only acommodate Mini-ITX (small) motherboards, which are generally more expensive than their larger equivelants, and there are also no variations which can accomodate CPU's which would be the best option for your budget.
[snip]
Far more powerful system for gaming. You could put a blue LED fan in the front if you wanted to mimik the look of the smaller case.![]()
Would anyone be able to speak for the AMD A8-6600K
Seems to be the same price and has an extra 100mhz. Just sayin.
