I don't understand how you get through it so quickly....
Reset and got 112 HCs. Not sure what to do now.... I'm getting through it stupidly fast. And when I get 100 ACs, then what? I think I'll wait for dungeons to come out of beta.
	some visual effects have been completely rewritten and should now run more smoothly (and be less CPU-intensive)
new upgrade tier
new milk tier
cookie chains have different capping mechanics
antimatter condensers are back to their previous price
heavenly chips now give +2% CpS again (they will be extensively reworked in the future)
farms have been buffed a bit (to popular demand)
dungeons still need a bit more work and will be released soon (you can test an unfinished version in the beta)
-added a new heavenly upgrade that gives you 5% of your heavenly chips power for 11 cookies (if you purchased the Heavenly key, you might need to buy it again, sorry)
15/10/2013 - it's a secret
-added a new heavenly upgrade that gives you 5% of you heavenly chips for 11 cookies (if you purchased the Heavenly key, you might need to buy it again, sorry)
-golden cookie chains should now work properly
15/10/2013 - player-friendly
-heavenly upgrades are now way, way cheaper
-tier 5 building upgrades are 5 times cheaper
-cursors now just plain disappear with Fancy Graphics off, I might add a proper option to toggle only the cursors later
-warning : the cookie monster add-on seems to be buggy with his update, you might want to wait until its programmer updates it
15/10/2013 - a couple fixes
-golden cookies no longer spawn embarrassingly often
-cursors now stop moving if Fancy Graphics is turned off
14/10/2013 - going for the gold
-golden cookie chains work a bit differently
-golden cookie spawns are a more random
-CpS achievements are no longer affected by golden cookie frenzies
-revised cookie-baking achievement requirements
-heavenly chips now require upgrades to function at full capacity
-added 4 more cookie upgrades, unlocked after reaching certain amounts of Heavenly Chips
-speed baking achievements now require you to have no heavenly upgrades; as such, they have been reset for everyone (along with the Hardcore achievement) to better match their initial intended difficulty
--made good progress on the mobile port
v 1.0383 out:
So that's five new upgrades and a new achievement as well.
HC benefits are now not reaped immediately on a reset, but have to be purchased though a series of five upgrades from 11 cs to 1,111,111,111 cs. You get the Wholesome achievement when all have been purchased.
Whats all that extra stuff on the guys screenshot a couple of post above? like next cookie etc? I don't have that..
Up to 500 HC now, need more updates![]()
Playing it too much! Onto my fourth prestige, got all the achievements on the third one so ended up with quite a lot of chips from it.
