Ask her to contribute towards the cost of it if she wants to use it.
Other than that no.
If she streams any movies or other copyrighted content you would be blamed as it's your connection. Under no circumstances should you let her use your wifi
The only question, is she hot? if not No.
Don't broadcast your SSID and tell her that you don't have it.
I would like to do this , but doing the above ,does that mean all you wireless devices cant connect to the hub?
sorry not very techie.
That's a two way street, if you constantly download stuff you shouldn't, then you can set yourself up with a scapegoat![]()
No, you just select 'other network' or whatever, and type in the SSID manually.
You can still manually enter it, it just won't show publicly to every neighbour with a smartphone.
