***The Vapers Lounge***
Status
Not open for further replies.
Any reasons why?
FINALLY got my RSST wicking correct, although it's still not 100%, hold the button and it sometimes won't fire...strange...also, my Protank 2 splurged in my mouth, so, recoiled it, and it leaks, re-coiled it AGAIN, leaks through both ends...
Mail Allnamestaken a bunch of your Protank heads to recoil and send back to you. That's what I'd do. :D
Well thats me finished with the KFL, been trying for the past few hrs to get it working ie coiled and wicked and nothing...everything tastes like ****.
So in my anger i threw the kfl out my window then realised...ooops so went out to find it and found it smashed to pieces, guess a car ran over it. £60 odd quid down the drain but meh it only ever worked twice for me so no big loss.
Back to my working protanks, at least they work even though sometimes the heads are a bit hit and miss but when the head works on them...they work great.
I'll be honest even with the kfl working properly, it was slightly better than the protank but at least with the protank, you just fill it and go...simples.
****ing KFL, bane of my life.
Genuine LOL.
I love rage. :D
Genuine LOL.
I love rage. :D
LOL yep definitely not a good day for me, knew i shouldnt have bothered to pick up the kfl to try and coil/wick it lol.
Anyhow life goes on but life has ended for the KFL sadly...RIP KFL, you wont be missed you fiddly little **** thats for sure:D
Are the metal bits still intact? you still have the metal casing that came with the KFL? send me the remains ill salvage thy burden.
Good thing it didn't hit someone on the head when you threw it out the window.
What are u like Yas lol. :eek::p
can u not use the metal casing instead of the plastic tank?
Even a car running over it shouldnt damage the deck or drip tip
I've had several expensive mods you need to coil and failed at every attempt. I think I once got one coil working reasonably well and this is after spending hours on it and reading every bit of information on it. My friend is the same.
Some people were just not made to coil. These days cartomisers and the like are so cheap from China it doesn't really matter anyway.
So ive just tried that snake oil. Its alright but nothing special and leaves you with a dry throat more than others. Suppose i better let it steep for a month then retry it.
Just try again in a few days - it's the anise that hits hardest when fresh that puts a lot of people off. It mellows after a few days steeping.
Persevere - it's definitely a good juice, but if you really don't get on with it, I'll gladly "dispose" of it for you :p
Why do I need 2 RSST's? I can't even sell on UKV site...shame...I have going spare and I only wanted to advertise it for £22...damn shame that...
LOL nah i checked before i threw it out, last thing i needed was someone suing me for causing them head trauma with a KFL lol.
Yas - buy yourself a cheap dripper (I have the Igo-W, but there are many others, some suit your Provari better) and send it on to me. I'll microcoil it and put a small cotton wick inside, and return it with enough cotton to last a significant time, then return it to you.
All you'll need to do then is prime the cotton with a few drops of your favourite juice, wait 5 for the cotton to soak up, turn the voltage down and attach it to the mod, then gradually working your way up until you have the sweet spot and and enjoy the vape of your life!
If you don't like the flavour, remove the cotton, dry burn the coil and re-wick with fresh cotton and try again with a different flavour,
(Although you'll need to remind me which Provari and batteries you have, so I know what minimum resistance you need :cool: )
Crikey i have days like that, but ive never thrown anything out the window lol, i too am having trouble getting my kfl working, must be going around lol
Will chat to you via trust later & work things out :cool:
Thanks :) currently using my standby evod :( dear god what a horrible vape compared to the kfl and the drippers im used to but it works lol
Status
