Gibbbbbooooo msisssssss memory you plxxxxxxx11111
MSIiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
TOP PLAYER
TOP CHOICE
Still not here!!
When it arrives I will check, but right now, its on a truck, on a road, somewhere in the UK!
Just woke up, my £450 guess all along wasn't bad was it
These cards look excellent, very tempted.
Great to see AMD delivered on the competition front and also with pricing.
Has 8 pack had a go on these yet?!![]()
Do we have a solid figure on how much power these draw?
A lot, Hexus have it at 275![]()
That's less than a ghz 7970 so it's not too bad![]()
Yes, it would be capable, but given the heat this card seems to put out, if I was WC it, I would be doing so to get best out of it so would want as much rad space as possible. Dont think I would go to expense of WC it without 2x120 rad space at least, in its own loop. In a loop with CPU would be 3x120 minimum, but most likely 4x120.
Also depends on the thickness and efficiency of rads, plus tr kind of fans and acoustics you are willing to bare!
TOP PLAYER
TOP CHOICE
Still not here!!
ahhh...the horrible feeling of having finished with the appetisers, but main course no where to be seenMSIiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
TOP PLAYER
TOP CHOICE
Still not here!!
I am planning on slapping a 290x into my 8350 system and OCing both underwater. Anyone think 750watt OCZ Fatal1ty PSU is going to cut it?
Currently its doing a 580 and the 8350.
Thanks i wasnt sure, il probably try fit a 2x120 rad in if possible
