- 27 Feb 2012
Will quickly hook up the 1440 screen and test a single 780 for that, got nothing better to do!!
I think AMD needs new drivers. For the 2 indoor scenes with the prisoners I get 2 big lag spikes for the short moments the scenes change. and the frames for those 2 scenes seem to be much lower than the rest of the bench.
Gonna assume it's down to physx? I can try running without physx and see.
all max
8x msaa
7990@ 1100 1575
cat 13.11 b6
Physx normal
1200p
11 min
147 max
87 average
1080p
12 min
158 max
91 average
Batman without PhysX is like BF4 without mantle... oh wait...
all max
8x msaa
7990@ 1100 1575
cat 13.11 b6
Physx normal
1200p
11 min
147 max
87 average
1080p
12 min
158 max
91 average
How do you run PhysX with a AMD card.
eh of course u can, just install physxI can only use normal mode tho and not high.
Ran again without physx, those 2 scenes (with guards) run fine.
Something about AMD/Physx doesn't like those 2 scenes indoors. I am going to assume those 2 scenes are more physx intense than all the others.
Yeah AMD cards just can't handle it as it will move to the CPU and then your CPU can't keep up with your GPUs.
Drivers won't fix that I'm afraid. Getting a couple of 780s might though.
jus wait till i say the same with BF4.
"Nope aint gona fix it, buy a couple 290x's"
edit:
dont have newest physx installed >.< doubt it'll do much, will try.
Difference being BF4 will run just fine in Dx mode. Mantle is an unknown. A very interesting unknown.
Im not trolling ived use ATI cards ever since I had SLI 8800s I never knew ATI could do PhysX.
Im 55 got 4 grandkids im not a gfx card fanboy I just never knew.
It's pretty obvious to use PhysX fully you need a nvidia card. nvidia is slapped all over the video.
