I ordered something surface mail from Colorado and it took from September till December to arrive
I used the card for 9 months![]()
Awesome man, got a card aswel?![]()
Yep, Got Asus card on monday, got the full N+A block and back plate. I will fit it in a bit later and run tests![]()
Getting my Sapphire within 5 days (Hopefully ... )
I didn't really explore the OC'in side of the 290x until I got the water block. I must say the block looks like geek porn.
Hi. Are people's BF4 codes now working? I know there were a few who reported problems before/at the start of the week. I've entered my code as instructed but it tells me that the origin code is 'Currently Not Available'. Thought it should work and I would be able to pre-load at this stageAnyone else getting the same message?
Hmm.... So I assume most of you have received the Origin code then and are able to pre-load![]()
ughh i cant wait... Im getting impatient![]()
Thanks to Scramz and Mitch9y. Seems like luck of the draw but I have emailed them to try to get sorted.
