You don't pay much attention to monitors, then? VA is one of the three main LCD panel types.
Might not have gotten as much glory as the IPS recently, but it's indeed one of the big players.
Only seen TN and IPS panels.It's actually 23.5" diagonally![]()
I have the xl2420t atm and whilst its great for the likes of bf3/4, The colours look so washed out in general use its horrible, Is this 240hz VA panel likely to feel as smooth as the xl2420t whilst having much better colours?
Lian li pc60 remember those
ordered one .. £455.94 GBP delivered ouch.
But I'm selling my 19' IIyama monitor a corsair psu and lian li pc60 case to a mate for £100 got a bargain...to make up the difference from the benq was about to orderLian li pc60 remember those
Doesn't screen tearing usually occur when your FPS is higher than your refresh rate? Don't think you'd need to worry about G-sync at 240hz, lol.
I think G-Sync is meant to have a noticeable affect to how smooth things are when frame rates are lower than vsync.
Don't know/understand why though.
I would also recommend anybody reads that article if they think screen tearing is only a factor if your frame rate exceeds the refresh rate. It's to do with lack of synchronisation between what the GPU is doing and what the monitor is displaying and occurs at lower frame rates than the refresh rate as well.
Eizo website said:EIZO’s five-year warranty is two years or 67% longer than the standard three-year warranty of most brands.
Nope I dontOnly seen TN and IPS panels.
Would love to see a TN, IPS & VA side by side in person, Then have a few fps's playing on them and purchase deciding on that.
Its a half way job, they forgot to make it 27inch and 2560x1440![]()
